A Really Annoying Wind Problem
  • 23 Replies
  • 5314 Views
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« on: March 21, 2004, 02:14:09 AM »
It's Spring here in the Southeast and Spring means wind, lots of it. After adding the bigger Coopers to the Tracker it has become almost uncontrollable in high wind. Do I need a Steering Stabilizer or is this something that I just have to live with? :-/
Re: A Really Annoying Wind Problem
« Reply #1 on: March 21, 2004, 02:17:24 AM »
??? A stock Trucklet is almost uncontrolable
in the wind, I swear if somebody sneezes out
the car window I go over half a lane, I think
it's a live with it issue, Sorry   :(
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #2 on: March 21, 2004, 03:18:20 AM »
I'LL TELL YA THE WIND REALLY MESSES WITH MY KICK, ON 32'S........YOU'LL BE DRIVING ALONG AND THEN WOOOOSH  YOUR ROCKING THE STEERING WHEEL BACK & FORTH JUST TO STAY IN YOUR LANE. IT USED TO BE A BIT SCARY, LIKE WHAT THE HELL , IS THERE SOMETHING WRONG WITH THE FRONT OF THIS THING OR WHAT. AFTER A FEW ROADSIDE INSPECTIONS & ALL APPEARED TO BE WELL , SO NOW I JUST FEEL AS IF I'M IN MY UPS TRUCK THAT HAS ATLEAST 3- 6" OF PLAY IN THE WHEEL . BUT HELL ITS GOT 655,000 MILES ON IT, SO I GUESS ITS LUCKY TO STILL BE GOING DOWN THE ROAD. THE BEST IS WHEN YOUR STEERING INTO THE WIND OUT IN THE  FLATS, AND THE WIND STOPS, & YOU NOW CROSS OVER THE LINE & PEOPLE THINK YOUR SWERVING AT THEM  ;D SO I GUESS ITS A LIVE WITH ISSUE. MATTY D.  8)
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
« Reply #3 on: March 21, 2004, 04:01:09 AM »
The Sidekick/Tracker are very prone to high winds.  I've had some freaky moments too, especailly out in the country, but nothing overly serious.
Offline Mike71
  • 1449
« Reply #4 on: March 21, 2004, 06:01:14 AM »
i have just a stocker..but when i switched to a hard top the wind has kind of left me alone..head winds or side winds i can drive across the bay bridge and dumbarten bridge w.o vering all over the road lol
Offline TinTopper
  • 73
  • 1987.
    • dayid.org
« Reply #5 on: March 21, 2004, 07:06:24 AM »
Open your windows - remove your doors - wind passes right on through.
'87 TinTop
'04 F-150
Offline TN_Tracker
  • 1113
« Reply #6 on: March 21, 2004, 07:46:38 AM »
Very interesting! I find it hard to accept that a vehicle so well engineered would handle so poorly in a windy situation. There has to be a cause.
Upon further inspection it seems I have a bad sway bar bushing. It may be the problem.
Offline Mike71
  • 1449
« Reply #7 on: March 21, 2004, 08:31:50 AM »
they do have a wind problem just because of the ammont of surface area on the sides and lack of weight..but what may be for u is that the problem is even worse because of the bushing or some other thing..u should feel out of controll in the car just the wind should be more of a presence then in other cars
Offline Speedracer7c
  • 2210
« Reply #8 on: March 21, 2004, 10:36:07 AM »
my tracker is all over the road too. I think its probably just cause they don't weigh anything and they are shaped like a block. Not exactly aerodynamic.
Offline Samurai_Hamster
  • 28
    • Samurai Hamster
« Reply #9 on: March 21, 2004, 10:46:23 AM »
With the stock uni-won't royals, handling in high winds was a bit of an adventure.......even in a stock 4 door!  :-/
Since I installed Cooper Weathermasters, that issue is not nearly as bad but its still there.  Makes the bunghole pucker up big time when an 18 wheeler is a hammerin' down in the left lane and you're on a rather high bridge!  :o 8) ::)
Offline TN_Tracker
  • 1113
« Reply #10 on: March 21, 2004, 10:52:55 AM »
It seems Autozone sells greasable poly bushings and brackets for the sway bar. Anybody know what the sway bar diameter is on a '96 Soft Top Tracker?
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #11 on: March 22, 2004, 07:05:04 AM »
Wind is my worst enemy. Weve had 35mph winds lately and they have been kickin my rigs ass all over the place. One day last week I was driving into a nasty headwind and had to shift into 3rd! My top speed was only 42mph for at least a mile. :o The way home was a breeze.... :P
I really hate the sidewinds. Most of the time its just a little anoying but the other day I actually got off the freeway and took sideroads.  However, I did see other vehicles having trouble too.
Mike
Offline Mike71
  • 1449
« Reply #12 on: March 22, 2004, 07:16:10 AM »
why does shifting into 3rd help with the wind? i dont understand ???
i know im slow bare with me =)
Offline TN_Tracker
  • 1113
« Reply #13 on: March 22, 2004, 07:19:16 AM »
A little update. I crawled under the Zook today and it was worse than I thought. Seems the Auto Trans Lines had been leaking just enough to ruin the rubber sway bar bushing, it's turned to jello. Put a caliper on the bar and comes out to be 24mm. Of course Autozone doesn't stock this size and I have to order it. Does anybody have experience with Energy Suspension Products, good stuff?
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #14 on: March 22, 2004, 07:27:17 AM »
Cause I was bogging out in 4th and 5th. The headwind was that strong.
Mike
