Ooooooo OTT Stuff Here! (Graphic Intensive)
  • 33 Replies
  • 7958 Views
Offline hcgalvin
  • 1695
    • Granite Path
Re: Ooooooo OTT Stuff Here! (Graphic Intensive)
« Reply #15 on: March 22, 2004, 12:17:08 AM »
OK.. some more pics of it going together.... we managed to get the whole assembly "in" the truck last night, we found out we had to cut the floor for the sammy tcase to fit..  :P So it was slow going trying to maneuver the whole unit in and out of the truck a few times to get it situated right. Will be working on it some more tonight.
Had to bend the stock sammy 4x4 shifter back because of clearance issues with the sidekick manual transmission. It wouldn't clear in reverse and 2hi:
Hole in Floor (ended up being slightly bigger than that, but all able to fit under the front passenger seat rails):
More to come!
Heather Galvin
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #16 on: March 22, 2004, 07:33:17 AM »
Mabey I wasnt fully paying attention but I didnt realize that we are doing something very simmalar as far as T cases go. Im installing a SpiderTrax Thorax and a Calmini 5.14 to 1 in a Sami case behind it. Same thing only different. It will be neat to see the two side by side.  ::)
Mike
Offline 92Sidekick4x4
  • 1456
« Reply #17 on: March 22, 2004, 09:43:14 AM »
idahoLWB" whihc way did u coem through? you drove to BC right?
Offline pbgbottle
  • 76
« Reply #18 on: March 22, 2004, 10:09:49 AM »
Ya Dude wich way did you come . if you hit the truck crossing you drove right past my front window . and you didn't
                   HONK  !
                                   CONGRADULATION'S on the purchase there guys ,can't wait to do this to my 4dr sidekick .SWEET !  i'm busy building my small block powered cruiser with spring-over and 38's right now ,then will start in on the sidekick . keep us updated .
                       Jake the snake
1997 suzuki sidekick
4dr. auto
Calmini 6 inch
31x10.5 yokohamas on american racing 15x7
see the machine at http://www.cardomain.com/id/pbgbottle
Offline 1bigtracker
  • 3409
« Reply #19 on: March 22, 2004, 01:01:15 PM »
just a question.  how long is the second case and adapter?  just wandering about doing it on a highly lifted 2 door tracker.
stu
Offline Yankee Tim
  • 431
  • Who says a GV is a grocery getter?
    • Yankee Off-Road
« Reply #20 on: March 23, 2004, 12:14:48 AM »
Mike
Gearing selection and such will be identical.  The nice thing I'm preceiving about the OTT set up is everything is married together, hopefully translating to less driveline wind-up.  The more "links" made via ujoints, rubber mounts and such.
I like the Kicker 2 option for a LWB Kick or GV ( ;) ).  This marries the Toyota t-case to the kick low-range.  The t-case is stronger than either the Kick or Sammy t-case, but it's also bigger and gears do cost more.  But the Toy case has fixed flanges (a big plus) and a correctly centered rear output translating to better driveshaft harmonics.
This also leaves you perfect for Toyota SAS conversion, as the driveshafts will only need to be lengthened or shortened, but are otherwise a bolt-in.
Hmmmmmm. ::)
Yankee Tim
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #21 on: March 23, 2004, 12:32:42 AM »
Oh, man, talk about being upstaged!  I'm gonna have the least "tweaked" Kick in the Idaho Slick Rock Corral!  Can't wait to see you guys in LESS THAN TWO WEEKS!!!!!!!!!!!!!!!!!
Roll-cage is IN.  Starting to think about dropping the tranny, to put in the clutch, and new lo-geared xfer case...   ;D
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
  • 6601
  • 68
« Reply #22 on: March 23, 2004, 01:04:21 AM »
Hmmmmmm. ::)
Wha-wha-wha-WHAT? Is this the real Yankee Tim? Putting Toyota parts in a Suzuki? Holy.... I need to sit down a minute.... Crap!  :o ;D
Eric
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #23 on: March 23, 2004, 01:07:39 AM »
Eric
I'm sure he was just speaking hypothetically, about somebody ELSES rig, not his precious GV...
Or he's back on the crack, because he can't go to Moab...
Bob
Offline Yankee Tim
  • 431
    • Yankee Off-Road
« Reply #24 on: March 23, 2004, 07:39:30 AM »
Eric
Well, if it were my Samurai, then yes, ultra purist while still trying to be hardcore. ;D  Is there such a thing?  Nope, mark my word, my Sammy will remain "Pure Suzuki". ::)
But my GV ain't that.  The purist bug bit me and left on the GV quite a while ago.  Too many broken parts, and it just ain't got the heart my Sammy has.  So yes, maybe someday, when the payments end (2005) I would consider the above mentioned mods.  I think a GV on 35's would be pretty tit.
Would I consider this mod?  Well, I did just buy a 1984 Toy truck, well, because it was only $200 complete (with a 3" body lift to boot).  You know, just in case.
The real reason I bought the GV in the first place was to guarantee a suitable H25 donor for my Sammy.
But a GV on 35's..... ;D
Yankee Tim
Offline Yankee Tim
  • 431
    • Yankee Off-Road
« Reply #25 on: March 23, 2004, 07:42:10 AM »
That's LSD, sir.  Get it right.  ;D
Yankee Tim
  • 6601
  • 68
« Reply #26 on: March 23, 2004, 07:49:45 AM »
Let's talk nomenclature for a minute. I've seen the V6 engines described as H25 for the 2.5 liter and H27 for the 2.7 liter on this and other forums. Is this correct? The wiring manual Stu, 95XL7, loaned me for the 2001 2.7 liter XL.7 says JA627. So, does anyone know whether the H is correct or the JA?
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #27 on: March 23, 2004, 08:07:04 AM »
That's Odd.  My SQ625 FSM (That's what THEY call the GV) oh, wait...  That's what they call the VEHICLE, not the motor.  SQ is the GV, with a 625...  So I'd guess a Vitara would be an SQ420?  JA would be the frame/body designator for the XL-7...
Bob
Offline Yankee Tim
  • 431
    • Yankee Off-Road
« Reply #28 on: March 23, 2004, 08:22:46 AM »
G13A, G13B, G16, ??18, ??20, H25, H27.
Strickly motor designations.  The XL7's motor is the H27.
Anyone know what the #s are for the 1.8 and 2.0 I-4 motors.  What about the 2.0 V6?
Yankee Tim
Offline Yankee Tim
  • 431
    • Yankee Off-Road
« Reply #29 on: March 23, 2004, 08:26:42 AM »
Yes, you are correct.  I;'ve seen a British FSM on ebay, and it had the designations on SQ416, SQ420, SQ625 and JA627.
Why they change to JS for the XL is beyond me.  Unless that leaves them room to evetually bump the GV up to the H27 motor when the XL7 gets the H30.
Yankee Tim
