fuel pump
  • 3 Replies
  • 2352 Views
Offline Sidekickguy_1
  • ZUKIWORLD Online!
fuel pump
« on: January 01, 2016, 04:37:46 PM »
Hi. I have a 1996 sidekick jlx sport with the 1.8 l. My fuel pump works great i just lost power to it. I don't know what it could be.
96 sidekick jlx sport 1.8L
Offline fordem
Re: fuel pump
« Reply #1 on: January 01, 2016, 05:31:59 PM »
Relay, wiring, or ECU - how do you know you lost power to it?
  • ZUKIWORLD Online!
Re: fuel pump
« Reply #2 on: January 02, 2016, 10:48:44 AM »
Well it just up and died on the highway like it ran out of gas so I figured it was the pump.  I got it home and dropped the tank and pulled the pump. I then stuck it in a bucket of gas and hooked it up to the battery charger and it pumped just fine. So I got my ohm meter out and had no power to the plug on the pump. Tried switching the relays around between the main and pump relay and still nothing. So I took out the tail light and rear speaker and checked the pink and black wire and I had power there and not to the plug. I direct wired it from there to the pump and got it to run. But I'm still not sure where I lost connection at.
Offline fordem
Re: fuel pump
« Reply #3 on: January 02, 2016, 02:41:29 PM »
What's between the pink/black wire and the pump?
