Manual transmission fluid question...
  • 2721 Views
Offline WVzuk
  • 181
« on: January 07, 2016, 08:17:42 PM »
So today I changed the transmission fluid in my 94 kick.  I noticed that there was only about 1-1.5 quarts that came out of the transmission.  I have no idea how it was so low.  I last changed the fluid a couple of years ago.  I have a gear whine I've been bit concerned about so I decided to change the fluid again.  I added Lucas oil stabilizer because I read that it helps quiet gear whine.  Anyway I was able to get a little over 2 quarts in before the fluid began to drain back out of the fill hole.
The specs say the transmission holds 3.2 quarts.  Is there always some still at a low point in the transmission so it doesn't all drain out?
1994 4dr Sidekick: 3inch Zukination lift, 30x9.50 mud tires, snorkel, ARB rear locker, homemade bumpers
Offline Capt
  • 738
  • 28
Re: Manual transmission fluid question...
« Reply #1 on: January 22, 2016, 06:55:38 AM »
Check your spec sheet,
It may be in metric as in liters,
and I have seen translated versions for the right hand drive
using the Imperial Gallons, quarts, etc....
Just a thought
Offline leelorr
« Reply #2 on: January 24, 2016, 07:29:18 AM »
I read that it holds 2.x quarts after a rebuild (dry), and 1.6 quarts when changing the fluid. I figured that this was because some of the fluid stays on the gears and case after you drain it...
Offline WVzuk
  • 181
« Reply #3 on: January 26, 2016, 06:49:35 AM »
Thanks for the replies.  The website I got the info from was misprinted.  It is in fact 3.2 pints or 1.6 quarts.
« Reply #4 on: January 26, 2016, 10:41:03 AM »
Thanks for following up with what you found.
