Drive shaft spacer
  • 12 Replies
  • 3449 Views
Offline 1bigtracker
  • 3409
Drive shaft spacer
« on: March 20, 2004, 12:10:33 PM »
I need a drive shaft spacer.  i saw 1 site that had them and can't find it now.  anyone know where to get them?
thanks  Stu
Offline stingerx
  • 43
  • THE WAY A ZR-2 WAS ORIGINALLY DESIGNED
Re: Drive shaft spacer
« Reply #1 on: March 20, 2004, 01:25:50 PM »
i saw them at www.spidertrax.com
Offline 1bigtracker
  • 3409
« Reply #2 on: March 20, 2004, 01:35:12 PM »
thanks, is the bolt paddern on sammy and tracker the same?
Offline rockrat
  • 196
  • Got Ringr
« Reply #3 on: March 20, 2004, 11:53:08 PM »
newer zuk flange 89 and up I do believe are the same pattern .. What size you looking for 1/2" 1" 3/4" I amy have some in the shop
95XL7
« Reply #4 on: March 21, 2004, 01:26:34 AM »
I bought mine from RRO,their listed under drivetrain at the bottom of the page. ;)
Offline 1bigtracker
  • 3409
« Reply #5 on: March 21, 2004, 02:49:00 AM »
I don't know yet, just wanted to know where to get one.  I finshed lifting the frame in the tracker and need a rear spacer.  has anyone else other than lil-truck done the frame lift?
Stu
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #6 on: March 22, 2004, 07:52:18 AM »
Stu
My cousin did it about 6 months ago. So far so good.  :-/
Offline 1bigtracker
  • 3409
« Reply #7 on: March 22, 2004, 11:46:28 AM »
i think this will help me huge when i'm in the mud.  you could always see two frame rail marks in the mud that i had gone though.  i guess its time to go out and "WOW" all the fullsize guys again.  dose anyone have any tips or things i sould know about this that would help.  everything is going smoothly but never know when i may need some help.
thanks,  Stu
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #8 on: March 23, 2004, 12:28:52 PM »
Rocker gaurds!!!  After I raised my frame I dented both rockers.
With the frame lower it's harder to hit the rockers.
32 MTR's Warn 8000i
Offline Mike71
  • 1449
« Reply #9 on: March 23, 2004, 01:00:11 PM »
what does lifting the frame mean? ??? ::)
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #10 on: March 23, 2004, 01:05:30 PM »
When you put on a body lift there is a gap between the body and the frame.
I've cut the middle of the frame from the suspention, raised it back up to the body and welded it back together.  This will give you more brake-over clearance (center clearance) but leaves the suspention lower for bigger tires.
Before:
After:
« Last Edit: March 23, 2004, 01:07:26 PM by lil_Truck »
32 MTR's Warn 8000i
Offline 1bigtracker
  • 3409
« Reply #11 on: March 23, 2004, 01:26:37 PM »
rockers are already dented.  but rocker gaurds are in the works anyway.
Stu
Offline Mike71
  • 1449
« Reply #12 on: March 23, 2004, 02:06:58 PM »
ahh..hey thats cool it would give a bit more clearence
also my grandpa in his 02 tracker dented the pass rocker enough that the door woudlnt open unless u really really pushed on it :o lol..well i was driving..but he told me to go that way lol
