SideKIck 15 MPG ???????
  • 6 Replies
  • 4268 Views
Offline hiper
  • ZUKIWORLD Online!
« on: February 13, 2016, 07:38:22 AM »
PLEASE HELP
Hi Guys,
I own a 1994 Kick with 8v, went over unit a lot and tuned up but it is getting absolutely horrible fuel mileage and I am baffled why it gets this bad mpg
Any Suggestions would be hugely appreciated!!!!
Here is a list of work performed already!!
Compression is good
New Timing belt
WaterPump thermostat and all hoses
Plugs, rotor ,wires and cap
Wheeel bearings
Thorly header with new o2 sensor
Straight pipe back to magnaflow muffler
235/ 75 -15 Grabber AT2
Cold air intake
Offline ranger88den
  • 279
  • 12
Re: SideKIck 15 MPG ???????
« Reply #1 on: February 13, 2016, 09:10:54 AM »
Does CEL work?  Any DTCs?  Condition of ECT sensor?  Oxygen Sensor?
« Reply #2 on: February 13, 2016, 10:52:14 AM »
235/55 tyres will reduce your fuel economy, they will also cause your mileometer to read low so you may be miscalculating.
Offline RJkick
  • 634
« Reply #3 on: February 16, 2016, 09:25:06 AM »
You should be getting way better mileage.  Disconnect the battery and hopefully your ecu gets reset and you may get an error code.  Sounds like you are in "limp home" mode
92 Sidekick 1.6L 16v Calmini\OME 4.5" lift 3" Body Lift OME962 springs in front w\.75" spacers OME955 in rear w\1.75" spacers Extreme Duty Strut Eliminator kit and rear ProComp MX6 Shocks 31X10.50 BFG A\T   Thorley Header   2" exhaust  Calmini front truss bar and stabilizer and skids   Custom Bumpers and Rock Rails  Limit Straps
Offline Thirty-Nine
  • 286
    • Subcompact Culture
« Reply #4 on: February 16, 2016, 09:30:11 AM »
Remember your odometer is off 6.54% by having 235/75/15 tires vs 205/75/15. Say you get 200 miles on your odometer. Multiply that by 1.0654 to get the new mileage reading and divide that by the amount of fuel you used.
For what it's worth, my '95 16V (2dr) kick with a winch bumper, winch, lift, roof rack, hard top, rock sliders, 235s and MT tires generally has been getting about 19 to 20 MPG.
Offline RJkick
  • 634
« Reply #5 on: February 17, 2016, 11:25:59 AM »
That's what I get as well with 31's, 4" lift, tube bumpers, etc.
Works well off road though
Offline jzap
  • 515
  • How difficult can it be?
« Reply #6 on: March 05, 2016, 10:49:42 AM »
What tire presure are you running?  My Tracker is the most sensitive vehicle to tire pressure I have ever owned.  It is '96 2dr 16V with 225's.  At the "factory recommended" (sticker) pressure of 23psi it gets about 22mpg.  If I bump that up to 32psi, it gets about 28mpg (but it rides like a brick).
Jim Z.
96 Tracker
66 Apache camper
