Body lift for 99 4 door
  • 4240 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: April 25, 2016, 01:09:57 PM »
I was n the low range site looking at body lifts, didn't see one for the 99 so I emailed them.  Only make the 1 inch kit KSP-BL1 for 4 doors as the steering linkage gets complicated.
What do you guys do to fix the linkage,  and is there anything other that needs to be done?  If I buy the earlier version 2 inch lift kit, will it bolt in?
My last tracker, a 93, had a 4 inch body lift, I'm sure I can figure it out but I'd rather hear from those with experience
Offline captwoody
  • 688
Re: Body lift for 99 4 door
« Reply #1 on: April 25, 2016, 02:24:04 PM »
its a case by case basis on steering linkage. I just loosened the aluminum flat bar clamp on the steering shaft moving it down 3/4 from bottom and 1/4 from top. it is a little stiff but has worked fine for the last year. or you can go to rocky road off-road and they sell the extension kit. I would try the bar clamp first and buy the kit if you are not happy. I have 2.5 suspension lift and a 2" body lift on my 01 2dr
Just a Newbie crushing one rock at a time,2x4 rocksliders,lowrange 2"suspension lift 2" body lift and skid plates,5000 winch,towbar,grand vitara rear springs,100watt lights,ARB compressor /air up kit,ARB RD209 LOCKER,Roof rack,tow hitch, General AT2 255/70/15 or 31/10.5/15 Mud tires , 5.12 Gear swap,off road tent trailer,LED Lights
Offline bandit86
  • 1641
  • elv8rguy
« Reply #2 on: April 25, 2016, 03:38:30 PM »
That's about the lift I'd like to go, but I think 1.5 suspension might be enough for me.  If anything I'd like a little more articulation and straighter cv angles
Offline beagle..t
  • 1239
  • 16
« Reply #3 on: April 25, 2016, 06:16:20 PM »
sky manufacturing I think I got my 2" from
Offline arced
  • 55
RE: Body lift for 99 4 door
« Reply #4 on: April 25, 2016, 06:30:23 PM »
Maybe with this, you wouldn't need any body lift:
2.5" Suspension System:
http://www.calmini.com/detail.php?b=2&m=7&t=1&p=747&n=
Offline bandit86
  • 1641
  • elv8rguy
« Reply #5 on: April 25, 2016, 06:42:34 PM »
That kit costs more than I paid for the tracker and all new brakes and parts to get it on the road...
The 2 inch body lift from rocky road is 140$usd, I can sacrifice some rise quality I guess
Offline beagle..t
  • 1239
  • 16
« Reply #6 on: April 26, 2016, 09:01:43 PM »
you could also use 2" square tubing
Offline bandit86
  • 1641
  • elv8rguy
« Reply #7 on: April 27, 2016, 04:52:41 PM »
Isn't the original body mount a lot wider than 2 inches?
Offline beagle..t
  • 1239
  • 16
« Reply #8 on: April 27, 2016, 05:38:33 PM »
make them so they sit above the frame mounts ...or spend the money. I would get the steering extensions thou just my 2c, steering shaft falls off and who know where it could happen. safety first and they are reasonable priced
