Before 98 and after coil spacers the same?
  • 2099 Views
Offline bandit86
  • 1641
  • elv8rguy
« on: May 21, 2016, 07:08:12 PM »
Is the pre 98 coil spacers the same physical size ad the 99 and later models? I have a set of spacers and the rear one won't go over the centering piece in the middle.  I thought the weight of the tracker would push it in place, but it did not, there is a 1/2 inch gap between the spacer and the frame piece it's supposed to sit again
The rubber isolator is supposed to be between the spring and spacer, I don't see how it would do that.  The cutout for the spring is snug as it is
Offline beagle..t
  • 1239
  • 16
Re: Before 98 and after coil spacers the same?
« Reply #1 on: May 21, 2016, 08:58:30 PM »
No they are totally different. When I bought my 02 I had to get Jeff to make me another set
« Reply #2 on: April 10, 2017, 04:47:00 PM »
Hi Herman,
I'm doing the same swap into 1998 Tracker. I was just told by TT that the only problem will be the fuel tank temperature sensor. They said that Aerio has this sensor but my Tracker does not. So, it might throw a CEL code. Have you run into a similar issue with yours?
Thanks.
Own: 1998 Chevy Tracker, 1.6L, 16v, 5spd, 4x4, 2dr, soft top
Previously owned: 1990 Geo Tracker, 1.6L, 8v, 5spd, 4x4, 2dr, soft top
