CARBURETOR!!!
  • 3779 Views
Offline RideorDie
  • 52
CARBURETOR!!!
« on: June 12, 2016, 04:51:44 PM »
Alright guys after several times of pulling my transmission and finally getting it going right I have found another problem. I took my first wheeling trip in it today at krocks and boy it was rough. My problem is when I go up a hill no matter the size it will eventually cut out and die. Guessing it is the carb. So me not knowing anything about a carb I need some info on what to do. It does great on level ground but when I start going up an incline it will eventually start cuttin out and then it will die. Hopefully someone can help me here it would be greatly appreciated.
Offline Jonny Rash
  • 1094
  • 21
Re: CARBURETOR!!!
« Reply #1 on: June 12, 2016, 08:50:13 PM »
It sound like you have a Weber carb. Post a picture.
Offline RideorDie
  • 52
Re: CARBURETOR!!!
« Reply #2 on: June 13, 2016, 07:32:24 PM »
I am about 99 percent sure that it is a webber carb. However I do not have enough cash in the pocket to go buying a new carb at the moment. I would like to know what I could do to get it to work atleast a little bit better. Atleast to where I can crawl a bit. Do you have any tricks.
Offline JohnJohn256
  • 6
Re: CARBURETOR!!!
« Reply #3 on: June 13, 2016, 11:08:00 PM »
I can't seem to find the thread at the moment. There is a thread with detailed mods to the weber 32/36 on this site for the issue your talking about. Involves some drilling and parts but didn't seem too bad to me. Ill keep looking to see if i can find it.
Edit: heres a couple
http://www.zukiworld.com/forum/technical-discussion-performance-modify/weber-carb-1-3-conv-kit-tips/
http://bbs.zuwharrie.com/content/topic,123850.msg1227190.html?PHPSESSID=8c6f73a6401ed4904754e70ca1e8cadf#new
« Last Edit: June 13, 2016, 11:12:07 PM by JohnJohn256 »
Offline Jonny Rash
  • 1094
  • 21
Re: CARBURETOR!!!
« Reply #4 on: June 14, 2016, 07:04:54 AM »
The quickest and easiest fix is to mount the carb with the fuel bowl facing the firewall.  However, the carb will then run rich/stall on steep descents and during hard braking.
Offline RideorDie
  • 52
Re: CARBURETOR!!!
« Reply #5 on: June 14, 2016, 10:48:20 AM »
For now I put a fuel pressure regulator on it maybe that will work for a little bit until I can get something different figured out.
