Removing Wipers
  • 2573 Views
Offline LongRod
  • 28
Removing Wipers
« on: March 18, 2004, 06:53:29 PM »
   I have a 94 Tracker. This is a pretty basic question and I feel a little dumb asking it BUT how are the wiper arms removed?? I can lift them up on their spring loaded pivot and I can then rotate the wiper arm 90 degrees but I can't find a release button or lever. There is a blask plastic block with numerous slots and I believe it has the word "Bosch" engraved.  I do know that pulling and twisting doesn't seem to help. Is it possible that the arm isn't removeable and that all you can do is slide out and replace the rubber element?  ???
I wasn't always the dried out loser you see today; I used to be a moist and spongy loser!
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Removing Wipers
« Reply #1 on: March 19, 2004, 12:26:26 AM »
It sounds like you are talking about the wiper "blade" not the arm.
The arm is what moves the wipers back and forth.  The blade is attached to the end of the arm and holds the rubber part.
Anyway, the remove the wiper blade...  You can see the metal comes up and makes a hook.  On bottom side you can see a little hole.  The part in the middle will have some type of tab that has to be pushed in and the blade bracket will slide back and out of the hook.
32 MTR's Warn 8000i
Offline Bobzooki
  • 1754
  • Web Wheeler
Re: Removing Wipers
« Reply #2 on: March 19, 2004, 04:47:17 AM »
I was gonna say - to remove the arm all you gotta do is remove the acorn nut.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline LongRod
  • 28
Re: Removing Wipers
« Reply #3 on: March 19, 2004, 06:09:36 AM »
  Yes, I want to remove the blade part that holds the rubber element. I checked again and couldn't find any sort of "tab." I tried poking around with a small screwdriver in case the tab is recessed into the molded plastic block. It seems as if the blade and arm are manufactured as one part. The lower arm comes off after removing an acorn nut. I suspect that this is the OEM wiper. Possibly it's only the aftermarket units that have removable blades with the locking tab you mentioned. ???
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Removing Wipers
« Reply #4 on: March 19, 2004, 06:49:20 AM »
If you have a place like Auto Zone, go there and they will show you how to change them if you buy a new set from them.
32 MTR's Warn 8000i
Re: Removing Wipers
« Reply #5 on: March 19, 2004, 06:32:01 PM »
Tip, Buy the whole blade assembly, don't
just buy the blade inserts.
They will work better and they are new black
not all fadded, and they don't really cost
much more, and are a breeze to install, click
and drive away, all of 3 Min to change wipers,
and that includes getting them out of the package.
;D
Offline Mike71
  • 1449
Re: Removing Wipers
« Reply #6 on: March 19, 2004, 07:44:20 PM »
the blade and the arm are not one peice it just may be a little hard to spot..if u buy new blades on the back of the pakage it should tell u how to do it..thats the only way i changed my moms rear wiper lol the pos wouldnt come off. till i read the instructions that is ::)
Offline LongRod
  • 28
Re: Removing Wipers
« Reply #7 on: March 20, 2004, 11:57:38 AM »
  Instructions are always helpful. I posted my question here in hopes of receiving instructions. This may be a case where simple instructions without additional detailed photos aren't enough.
Offline Mike71
  • 1449
Re: Removing Wipers
« Reply #8 on: March 20, 2004, 12:22:11 PM »
yah i think for this kind of thing pics are a must...u can only explain so much
what sucks is after reading all this ull look at the picture and go..oohh s##t thats what they meant lol
but if u buy the wipers and still cant get them on post back here and ill take pictures of me dismantaling my wipers if i have to
hope u get them changed =)
