Suspension upgrade
  • 3106 Views
Offline Gbethel34
Suspension upgrade
« on: July 07, 2016, 05:16:06 AM »
I have a 91 sidekick and I put back seats in it so now the rear end is heavier and wants to bottom out. it has a 4 inch lift on 30s I thought about getting spring helpers or variable rate springs or a polyurethane brace that slips over the spring coil. This is my first sidekick so some guidance would be appreciated. Thanks
Sent from my VS985 4G using Tapatalk
Offline Ben.Peterson
  • 128
    • BPetersonDesign
Re: Suspension upgrade
« Reply #1 on: July 07, 2016, 08:36:15 AM »
Really need more info to diagnose.. They came with seats in the back from the factory, and the seat is super light.. I couldn't imagine that causing it to bottom out. Do you know what brand of lift is on it, and is it all suspension, or body lift as well?
Either way, something is wrong if just adding a 20lb seat is causing you to bottom out... The amount of fuel in your tank at any given time varies more than 20lb's.
04 4-Dr 4WD Tracker ZR2 - 235/75R15 General Grabber AT/2
97 2-Dr 4WD Tracker - IFS, 35's... and stuff.
« Reply #2 on: July 07, 2016, 04:59:44 PM »
While I agree with Ben, did you put longer shocks on the rear?  Longer shocks will bottom out earlier than shorter ones, and that will shorten their life.
