SUZUKI SAMARI SJ413
  • 2653 Views
Offline JAMES44
  • 46
SUZUKI SAMARI SJ413
« on: July 30, 2016, 09:14:47 AM »
The gear change has become quite stiff to operate....oil level is okay do the selectors need a drop of oil on them ????
      thanks jim
Re: SUZUKI SAMARI SJ413
« Reply #1 on: July 30, 2016, 12:48:13 PM »
Is the clutch properly adjusted? have you checked the gearbox oil level?
Offline td57
  • 76
« Reply #2 on: July 30, 2016, 10:15:18 PM »
Pull the shifter out of the transmission & check the shift pin & sheet.
It's could be that they either are broken or worn out.
Offline JAMES44
  • 46
« Reply #3 on: July 31, 2016, 02:12:46 AM »
Will check clutch aadjustment today thanks jim
Offline JAMES44
  • 46
« Reply #4 on: July 31, 2016, 02:16:00 AM »
will check also oil level is okay
     jim
