Sidekick antenna replacement
  • 4955 Views
« on: July 31, 2016, 10:07:49 AM »
My radio antenna is bent and I would like to replace it.  How difficult is it to replace?  Are there any special considerations?
Offline motofabio
  • 202
  • 6
  • 87 Samurai JX TinTop
Re: Sidekick antenna replacement
« Reply #1 on: July 31, 2016, 12:45:50 PM »
Easy peasy. It just plugs in to the back of your radio. The hardest thing is feeding the new wire through the pilar and finding it under the dash. Having a friend upside-down while you do that part is helpful.
« Reply #2 on: July 31, 2016, 06:34:50 PM »
Tie a length of string onto the old antenna cable before removing the antenna, tie the string to the new cable and use to fish the cable back into place.
Offline motofabio
  • 202
  • 6
« Reply #3 on: August 01, 2016, 01:12:33 AM »
Dammit. Yes, do that.
« Reply #4 on: August 01, 2016, 06:41:30 AM »
Thank you both.  Yes, I have a carton of pull string ready.  My luck would have some hidden attachment in an impossible to access location.
Sent from my SM-G900V using Tapatalk
« Reply #5 on: October 08, 2016, 06:41:29 PM »
I had a carton of pull string from when I pulled larger cable to my garage.  I pulled the radio out and tied the pull string to the antenna and tried to pull it through.  It got caught going from the crash bar under the steering wheel into the area under the A pillar and the cracked wire broke.  I used a fish tape to get the pull string up the A pillar to pull the new antenna back down to the radio.  The new antenna was a difficult to get into the a pillar, but I was able to squeeze it in and keep the gasket straight.
« Reply #6 on: October 17, 2016, 06:24:16 PM »
The antenna works better and runs up and down smoothly.  It was an easy fix to the problem.
Offline rasmeidirtrider
  • 76
« Reply #7 on: October 22, 2016, 08:54:22 PM »
A good lesson!
'96 (07/95) US imported Sidekick Sport, 16V, 1.8L, 4 auto, 4x4, 4dr, A/C, ABS, 100K miles, VIN: JS3TD21V6T4101985, bone stock, except 215/70R/16.
