Pumping gas pedal when starting samurai necessary?
  • 10 Replies
  • 3930 Views
Offline 6feetofAIR
  • 127
  • i wanna go to hawaii yayyyyyyyyyyyyy yy
« on: March 17, 2004, 08:07:02 AM »
Pumping gas pedal when starting samurai necessary?!? where's the beef?!?
ok people heres the beef, got my girlfriend a tintop samurai and in the morning its hard to start, first i was using not many pumps of the pedal but found out after time that i NEED to pump it vigorously to get it started every time it has been sitting for more than a day.
anyone know why it seems to be lean on fuel? float set too low or something? thanks in advance, 6feetofAIR
Offline Sami88
  • 45
Re: Pumping gas pedal when starting samurai necess
« Reply #1 on: March 17, 2004, 11:05:34 AM »
I've got a 87 hardtop that i bought a month ago.  I have to pump it quite a bit too.  I checked the carb and there is no choke plate.  I haven't been able to find one for it yet.  I think that will help me out alot.
88
Offline MB
  • 223
« Reply #2 on: March 17, 2004, 12:09:08 PM »
The only time I had to pump my 89, (the gas pedal) was when the air cleaner came loose and the rubber gasket somehow became lodged in the choke.
I never have to pump the gas, Now it did take a few extra cranks of the starter when I first got it. But a tune up and new fuel filter along with all new vac. hoses It starts on the first roll of the engine.
A proper choke setting would help (if there is one)-->sami88  ;D
Oh, and  correct timing goes a long way
« Last Edit: March 17, 2004, 12:10:26 PM by MB »
lucszuk
« Reply #3 on: March 17, 2004, 12:16:59 PM »
i have to pump mine too
Offline 6feetofAIR
  • 127
« Reply #4 on: March 17, 2004, 12:37:12 PM »
hey thanks for the replys. my samurai seems to do it just a little but the new one takes forever to start. new plugs wires cap rotor and correct timing are excellent ideas, although i havent done this yet(other than checking the cap and rotor just in case it looked bad) the thing is so hard to start it makes me believe that it has something to do with the carb. discuss and thanks in advance, 6feet 8)
Offline 6feetofAIR
  • 127
« Reply #5 on: March 18, 2004, 03:30:43 AM »
 :o bump!
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #6 on: March 18, 2004, 04:12:02 AM »
Hey, I remember those carbeurator thingies!  I had one back in the 80's!
Fuel filter could be a big issue, and fuel pump might be getting weak.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline TinTopper
  • 73
  • 1987.
    • dayid.org
« Reply #7 on: March 18, 2004, 09:09:39 AM »
It's a carb'ed vehicle... what do you expect?
I used to have to pump mine anytime... adjusted the carb and now I only have to do it when it's cold, but hell - I love in FL.
'87 TinTop
'04 F-150
Offline 6feetofAIR
  • 127
« Reply #8 on: March 19, 2004, 04:39:02 AM »
what did you adjust on the carb to get it to not be so bad? ???
Offline TinTopper
  • 73
  • 1987.
    • dayid.org
« Reply #9 on: March 19, 2004, 04:59:53 AM »
the cold idle
'87 TinTop
'04 F-150
Offline Edub
Re: Pumping gas pedal when starting samurai necessary?
« Reply #10 on: August 09, 2010, 05:04:24 PM »
Where did you adjust the cold idle.. can you snap a pic and show us? it would help us newbs a ton!!
