What size lift and tires
  • 2668 Views
Offline Swbuckmaster
« on: November 09, 2016, 09:29:05 PM »
Hope I'm not breaking any rules posting someone else's photos but I like the look of these. Can anyone tell me what lift and size of tires they have?
Re: What size lift and tires
« Reply #1 on: November 10, 2016, 10:31:57 AM »
They look like 31x10.5" tires for the most part.  Below is 33" tires with the fenders cut out in front and rear.
« Reply #2 on: November 10, 2016, 11:48:31 AM »
Thanks for the response.
What size lift do you think they have. I would think you have a bigger lift then they have to clear the 33's
« Reply #3 on: November 14, 2016, 12:01:28 PM »
They look to be running a Spring Over Axle life, or SPOA.  That gives you about 5-6" depending on how good of quality your springs are.   I like the basic kit from Sky Manufacturing or Low Range that gives you the cross-over steering and the wrap-around spring pads.  You don't need longer shocks to start off and saves you quite a bit of work, they can always be changed after.
You can fit 33" tires with a SPOA, but it's tight.  Most people add some taller springs as well.
