1994 Sidekick 4wd issue
  • 4 Replies
  • 2561 Views
Offline boothands
  • ZUKIWORLD Online!
« on: January 05, 2017, 12:23:47 PM »
I'm having some issues with the 4wd on my (auto tranny, manual locking front hubs) 1994 Suzuki Sidekick - in particular 4H. I can shift it into 4H, hit second gear, but right as it goes for 3rd it quite literally kicks me out of 4wd with a loud bang. I'm not sure if there is some particular sequence of shifting I need to do to get it to stay in 4H (I know some with manual hubs only work if you roll back in reverse a few feet), or if it's more of a mechanical problem. I'm not very car smart so I apologize if I didn't include anymore relevant info. Any help/suggestions would be appreciated.
Offline RBEBY
  • 21
  • BEACHIN
Re: 1994 Sidekick 4wd issue
« Reply #1 on: January 05, 2017, 05:37:07 PM »
Make sure all the tires are the same size, if not similar things can happen.
« Reply #2 on: January 06, 2017, 06:10:06 AM »
Are you in 4WD on a hard surface - these are part time 4WD so 4WD should never be used on a high traction surface, also, that "roll back a few feet thing" is an "auto hub" thing - manual hubs should disengage when you rotate the dial.
Offline boothands
  • ZUKIWORLD Online!
« Reply #3 on: January 06, 2017, 10:10:22 AM »
Ohhh that makes a bit more sense now that I think about it. It was a mix of high and low traction (fresh snowfall). Am I able to switch in and out of 4WD while I'm moving? If so, what speed is safe to do so?
Offline Perryd
  • 202
« Reply #4 on: January 06, 2017, 05:57:19 PM »
If your wheels are straight and your hubs are in the locked position you can change between 2h and 4h at speeds up to about 60mph.
1998 Tracker 2 door soft top, 3spd auto, 4x4, 215/57R15 BFG A/T, bone stock.
