Narrowest 15 inch tires for samurai
  • 5605 Views
Offline Cdnzuki
« on: January 06, 2017, 09:04:03 AM »
I could not find a thread with this topic.
I have an 86 Suzuki Samurai, it's stock other than a snorkel.  I run 235/75r15's with no rubbing at all.
I do 80% off road. I am needing new tires.  I will be doing a bit of a lift soon.  The biggest tires I want and need are 31's. I prefer a skinny tirelike 9-9.5.  Who makes a good 31 in a narrow tire.
Also how wide can you safely go on a stock Samurai rim ?
Offline TimmyD
  • 8
Re: Narrowest 15 inch tires for samurai
« Reply #1 on: January 07, 2017, 08:04:56 PM »
If you do a lot more off road, I would check out some Super Swamper TSL bias. They make them in a 31", but they also make them in a 29" version, and they are only 8.5" wide. My dad had the 32" versions on our Jeep and they were amazing tires off road, just not too good on road.
Offline olija
  • 770
    • Check out my cardomain
« Reply #2 on: February 19, 2017, 06:04:27 PM »
Yokohama makes the Y742S. Available in a 7.00-15 (roughly same as your 235/75/15), If you go up to a 7.50-16 it's  closer to a 235/85/16 which is roughly 32x9.5...but then you have to run 16" rims.
BFG also makes tall, skinny tires in lower load ratings for trucks like Suzukis and Toyotas. A 30x9.50 might be a good one.
« Reply #3 on: February 20, 2017, 10:57:21 AM »
If you look at metric tires you can stay pretty thin, especially if you jump up to a taller rim.
I'm with lija, if you don't plan on doing much of a lift you might want to look at a 30x9.5 instead of going all the way to 31.  Much easier to fit then.  You can use use a set of OME lift springs and swing them without an issue.
