Tracker 1.6 16v to Aerio 2.3 general questions/feasibility
  • 23 Replies
  • 16056 Views
0 Members and 16 Guests are viewing this topic.
Offline Perryd
  • 202
« on: January 06, 2017, 05:12:01 PM »
I recently picked up a 1998 2 door, and while the 1.6 is a good little motor I wouldn't mind having a little more under my foot. I daily drive an 06 Suzuki Aerio, and I just scrapped an 05 that I got for free. I'm holding onto the motor because maybe someday that 2.3 could find it's way into this tracker, if not it's just a spare for my DD.
If anyone knows anything about this swap, could you confirm what I would need to harvest from my parts car?
So far I took:
  • the engine
  • engine wiring harness
  • computer
I also have a spare 2.0 from a tracker that I'm pretty sure I'll need.
Is there any other wiring I need to take? There is still tons of body wiring left in the aerio, but I was hoping I could leave most of it as it's a major pain to get out. But I will go back and take more if need be.
I'm not sure if I'll ever do it, but from 95hp to 155hp just might be worth it.
I attached some are some pics of what I took out, hope to hear from someone else who did it, maybe some links to build threads? I've seen build threads from doing it to a sport but not a regular track/kick.
« Last Edit: January 06, 2017, 05:13:35 PM by Perryd »
1998 Tracker 2 door soft top, 3spd auto, 4x4, 215/57R15 BFG A/T, bone stock.
Re: Tracker 1.6 16v to Aerio 2.3 general questions/feasibility
« Reply #1 on: January 07, 2017, 05:25:17 AM »
There were a couple of vendors who offered kits to drop the J20a into the Sidekicks, so I would say the 2.3 (J23a) into the Sidekick is probably not too difficult, although that might depend on where you're starting from.
Was the donor Aerio manual transmission or automatic?  Is the recipient Sidekick manual or automatic?  If either one is automatic, your first challenge will be matching the transmission controller electronics to the transmissions, if both are manual, the task will be significantly less complicated.
You're going to need to hunt down a lot of small bits - oil pan & manifolds from a 2.0 Tracker or Vitara, cooling system plumbing, and that sort of thing.
Google Suzuki 2.0 into 1.6 swap or variations on that theme you should get some hits.
Offline Perryd
  • 202
« Reply #2 on: January 07, 2017, 08:06:20 AM »
Both are automatic, but I don't think the 3spd auto in the 98' tracker is electronically controlled is it? I was pointed to this link https://www.trailtough.com/index.php?option=com_content&view=article&id=71:donor-parts-list-20-engine-conversion&catid=36:techinfo&Itemid=60 , which takes a lot of the guessing out of what I need to take.
« Reply #3 on: January 07, 2017, 05:23:29 PM »
The 3 speed automatics weren't electronic, but, the Aerio transmission is - you're going to need the Aerio ECU to control the 2.3 and that will give you a bunch of errors when it doesn't see the signals from the Aerio transmission that it is expecting.
Offline Perryd
  • 202
« Reply #4 on: January 08, 2017, 09:30:50 AM »
Yeah that's what I'm afriad of, I don't care about CEL codes but I still need it to run well.  Hopefully I can use a manual aerio ECM with my automatic harness if that's not the case.
« Reply #5 on: January 09, 2017, 05:03:24 AM »
You should & will care about those CEL codes.  Having a standing CEL (from a communication error between TCM and ECM) means no warning when other alarms come in.  When it starts running crappy in the middle of vacation and your tools are home in shop it is SOL time.
The increased power of the Aerio does make it a good swap.  We ran one in Project Trouble race car, and 75 mph on gravel roads with 30" tires in 4wd  was no problem.
The TT wiring does not wire in the OBDII plug (there are only 4 wires) , this is NEEDED.  (We used their redrilled flywheel and didn't need an adapter to bolt it up to 93 transmission. )  The 2.3L does run hotter and you want their radiator and fan setup.
If you get the manual wiring, Volvo uses a non electronic version of the 4 speed auto, that can be used/converted.
I would try using a GV auto transmission behind your Aerio auto wiring.  There is a red wire and white wire that are used for communication between TCM and ECM on both models.  They may use the same communication format. or not.  I have not heard of anyone trying.  It is not going to be plug and play.
I can say integrating wiring is VERY time consuming, and it also takes more time than one thinks (and that is a long time).  If that sounds redundant read it twice, it takes that much time.
Offline Perryd
  • 202
« Reply #6 on: January 09, 2017, 03:18:27 PM »
I sent an e-mail to trail tough today, they were quick to get back to me to straighten a few things up. Your post has also been very helpful, thank you. Do you have any write ups/threads focused around the development of "Project Trouble" I feel like I could learn a lot from it.
So TT said it will have a CEL, and I'm ok with a CEL. I've daily'd cars with evap codes and such for years. What I didn't know is there is no OBD port at all? That's a different story. I'm ok with a CEL that's on for eternity but as you mentioned I'd be wary to operate such a modern powertrain without even a port. I use a scangauge II (basically an OBD II trip computer) that will show new as they come up.
I've been thinking about the transmission too, as I have a 4spd from a 99' sitting behind my garage. My image of it went in my head sort of like this: (I literally thought this up in bed so it might make no sense)
I know that putting a 2.3 in a track/kick/vit that came with a J-series is pretty well plug and play... (ex. sidekick sport 2.3 swap https://www.youtube.com/watch?v=8Gv67n53cUs)
So what if I were to use the harness/computer from a 99+ in order to run the 2.3 with the before mentioned 4spd I already have? Perhaps this would be easier than trying to get the 4spd auto to communicate with aerio wiring? Also this was I could retain the OBD II port as I would run the entirety of the 99+ wiring/ECM.
I'm just thinking out loud here, so feel free to let me know if I'm out to lunch. I'm just doing my part to continuously develop the much needed dialogue regarding what I believe to be the ultimate genuine suzuki swap.
Offline Jstr
  • 10
  • ZUKIWORLD Online!
« Reply #7 on: January 10, 2017, 05:52:48 PM »
I just completed this swap this summer. It nice extra power, lots of fun to drive. But it does come with some interesting problems.
For the swap and some finished fitment photos, see my thread in the build diary section, 1.6 to 2.3 in 95 Sidekick.
The auto causes the biggest issues. I used the auto from my 2000 tracker donor. The switches for the power mode and overdrive are missing in the 95 shifter, the 2000 assembly didn't fit in. So opted to keep the power mode on permanently, recommend this, and added a micro switch for the AOD. The setup works great and its fun having power mode engaged all the time, adds to the peppy, fly by the seat, fun to drive feel. I am still running stock gears, tires and suspension so its really noticeable. Will eventually switch to 5.12 gears and 32" tires, looking for a rally type setup.
You will need a donor 1.8l or 2.0l engine for oil pan and other rear drive accessories. Mine is a 2.3l block and head, used rest of parts, intake, exhaust, fuel rail, injectors, harness and computer from 2000 tracker donor. It's easier then getting the 2.3l computer to mate to and accept the auto tranny. I didn't dyno it but the butt feel while driving tells me it's peppier than my 2002 2dr Tracker. You will also need the dash harness, which was modified by Trail Tough to make it work best.
Now since doing it one way, and thinking i may do it again in a tin top, I have a few different ideas to do it.
Now since you have a newer version than I, it may be a little different, smarter folks than I can chime in.
To me, having only looked and not done the measurements to confirm yet.  I would get a donor 96 - 98 sidekick sport with a 1.8l and manual, but auto may work.  Since the interior and dash to the 96 - 98 sidekick and sidekick sport looks the same, and under hood dimension are similar (to be confirmed). I was thinking swap engine, harness, dash, harness and tranny from the sport to non sport model, this gives you a fully functional 1.8l and complete harnesses in place of the 1.6l. Once this is in and running, swap out the 1.8l for the 2.3l like the article for the swap in the sport model. This seems like an easier route than my first swap. Again this is just my plan in my head at this time and haven't finished the research into the swaps, other than learning from my errors and problems from my swap.
1995 Sidekick 2dr soft top with 2.3L auto swap.
2002 Tracker 2dr soft top - bone stock.
Offline Perryd
  • 202
« Reply #8 on: January 11, 2017, 04:21:03 AM »
Jstr, Thanks for you input. I had a feeling that would work well, but now I'm wishing I kept the wiring harness from the 99 I parted out. Shouldn't be a problem to get another if it comes to that. I look forward to reading your thread. One question though, were you able to retain the OBD-II port from the 2000 wiring?
As for using the 4spd auto from the 99 as BRD HUNTER mentioned, I'm going to give that a shot. I have almost the whole wiring harness from the headlight to the fuel tank removed, and I mean ever last wire. My plan is to getting it running on a stand and see if I can get the aerio ECU to communicate with the 99 4spd. The plug and wiring look very similar, so I'm hopeful that I can get something to work, and if I can't maybe you guys would be able to offer some advice.
Stay tuned for updates
« Reply #9 on: January 11, 2017, 06:29:31 AM »
If you are using the 99+ wiring & computer, it would have no problem with the  99+ 4 spd auto & computer.  You may incur a slight loss in power do to differences.  The main differences that I noticed between Aerio 2.3 and Tracker 2.0 was exhaust manifold (which needs to be switched to run stock motor mounts), and Intake.  Both of these can influence hp dramatically, without testing it is unknowable what the losses are.  I do not know if the Tracker wiring will plug directly into Aerio motor.
Project Trouble is in the Build Threads.  We started building the Desert Racer for ZW series, and I found a T-boned Aerio that I could part out for more than it cost and have this motor.  So we threw in in as fast as possible and went to the races.  We ran in 4WD because it was much more stable at higher speeds, and helped on some of the steep climbs.  At 75 mph there was still more throttle left, but that was fast enough on a gravel road I hadn't driven before (and didn't know where next turn off was).  Side note: we did not finish any of the big races, but had enough fun to stay with it until our class disolved from lack of participants.
One of the problems with the TT harness is a tachometer reading, they have to modify your tachometer to get it to work???  I am not sure what wire I used (now), but we didn't have any issues with tach.  possibly I just used #1 coil signal wire.
This may be of interest to you. http://www.zukiworld.com/forum/technical-discussion-performance-modify/2-3-aerio-to-tracker-conversion/, not sure if Herman is still very active.
Offline Perryd
  • 202
« Reply #10 on: January 11, 2017, 11:04:08 AM »
Thanks for the suggested reading, lots of great ideas floating around. 2.0 wiring with 2.3 guts is looking more and more like the better option. Dang, I really wish I kept the wiring from the 99 I scrapped :(
Offline Perryd
  • 202
« Reply #11 on: January 11, 2017, 11:35:49 AM »
This was very insightful, he mentions that he needed to "hook up a scan tool to verify the RPM and remove the tach needle from it's post and re position the needle to calibrate." He also used to the trail tough wiring. I believe you mentioned earlier that they never wired in a plug? I'll have to email trail tough and see what's up with that. He said it would have a standing CEL but didn't say much about a port.
Offline Jstr
  • 10
  • ZUKIWORLD Online!
« Reply #12 on: January 11, 2017, 11:56:34 AM »
Search and read all the 2.3L swap threads. We all did it a bit differently and all have slightly similar results.
I sent both the dash harness and speedo to TT. They did whatever and sent it back. Works great no CEL or codes. I used complete dash and engine harness from 2.0L to make swap easiest at my end. I have had it up to 120km/h no problems and with power mode permanently on the throttle response is great. I had the advantage of a shop that cured any wiring issues and was able to reset the computer. The OBD-II connector from the 2.0L was retained and used for diagnosis. I wish i had used the larger 2.3 fuel rail and injectors but wasn't sure the 2.0L computer would work them right. May still install them to see but that's for another day.
The interest in my thread fizzled so didn't  do a complete write up. Plus I am not that different that some of the existing ones.  BRD HNTR was a great help and TT was too. I would also recommend their motor mounts. And manual is much simpler if you can go that route.
Sounds like you are on the right track. Any questions, ask away.
Quick recap of what I used from which donor.
2005 Aerio 2.3L - Head and block.
2000 Tracker 2.0L - complete engine, tranny, dash harness, computer, intake exhaust manifolds, fuel rail injectors, accessories. Welded a pipe from stock 1.6L exhaust to 2.0L manifold.
« Last Edit: January 11, 2017, 12:03:02 PM by Jstr »
Offline Perryd
  • 202
« Reply #13 on: January 11, 2017, 12:11:03 PM »
The more research I do the more attractive this swap looks from the wiring perspective. One thing I'm wondering that doesn't seem to be addressed though is the ignition cylinder and key. I don't think these vehicles have this issue because I've gotten keys cut at the hardware store, but I wanted to make sure. Were all you guys able to use the stock track/kick key and ignition cylinder with your new wiring. The reason I ask is because I have all the parts mentioned above except for dash wiring from a 2.0, and the pick and pull yards never have the keys.
Offline Jstr
  • 10
  • ZUKIWORLD Online!
« Reply #14 on: January 11, 2017, 09:55:11 PM »
My dash and column are the stock 1995 Sunrunner. I didn't so the harness install personally, friend much more suited to it than me did, but we never discussed a compatibility issue there.
Check with Brent from TT if you can reuse the 1998 dash harness. There are alot of similarities in the two harnesses.
« Last Edit: January 11, 2017, 10:01:27 PM by Jstr »
