play in steering samari
  • 2008 Views
Offline JAMES44
  • 46
« on: May 29, 2017, 02:59:32 AM »
  Hi
       There is about one and a half to 2 inches of steering wheel free play...what do other owners find on theirs ??
          might adjust it on the steering box later..or leave alone
                  Jim
Offline TinTopTom
  • 27
Re: play in steering samari
« Reply #1 on: November 16, 2017, 08:34:49 AM »
2" at the steering wheel isn't gross, but I'd check the steering system out, especially if this is a new symptom.
If you have a helper, you are better off. Start with the steering box, have your friend work the steering wheel back and forth while you're underneath.
Check the steering box for loose at it's mounting, or the frame is rusty at the box mounting holes. If that checks out, check the pitman arm for looseness on it's spline shaft.
Then the steering rod tie rod end at the pitman arm, the one at the tie rod, then both tie rod ends. Typically you'll find a torn tie rod end boot, it's gotten water inside, deteriorated, and needs to be replaced. If one is bad, I replace all of them (I assume they are all the same age, when one goes, the others aren't far behind). The last thing I do is try to take out play by tightening the steering box adjustment screw.
Building stuff is a way of life
