Trans issue
  • 9 Replies
  • 3729 Views
Offline kreator
  • 634
  • 15
Trans issue
« on: July 17, 2017, 09:23:33 AM »
I did a engine and auto trans swap into my tracker with the complete wiring harness . When I start it up I can turn the O/D on and off but when I drive it the light flash's and wont shift into into second and goes to drive and then O/D .Its a 1993 Kick trans with O/D . Any thoughts ? Can it be a cable adjustment ? Is there a way to check the wiring for an issue ? Thanks for any help I can get .
 It came out of one of my rigs that got wrecked and was working fine,
« Last Edit: July 17, 2017, 09:27:24 AM by kreator »
Re: Trans issue
« Reply #1 on: July 17, 2017, 03:55:04 PM »
A 93 will be OBDI - and can be diagnosed using a paperclip - you may have a broken wire in the transmission harness.
http://rhinopower.org/diag/diag_main.html
Offline kreator
  • 634
  • 15
Re: Trans issue
« Reply #2 on: July 17, 2017, 07:29:08 PM »
the check engine light works and gose out when it starts .
Re: Trans issue
« Reply #3 on: July 18, 2017, 05:20:23 AM »
I'm fairly certain that the OD light is used as a transmission code indicator on the vehicles with a separate transmission control module.
Offline kreator
  • 634
  • 15
Re: Trans issue
« Reply #4 on: July 18, 2017, 09:14:07 AM »
Thanks I will resurch that and check the flashing
Offline kreator
  • 634
  • 15
Re: Trans issue
« Reply #5 on: July 18, 2017, 04:02:17 PM »
well the trans code is 24 #2 shift solenoid short circuit now I need to find out how to clear and repair
Re: Trans issue
« Reply #6 on: July 18, 2017, 08:26:26 PM »
Possibly a pinched wire in the harness - if you can find the connectors the coil resistance should be in the 11~15 ohm range - disconnecting the battery may or may not clear the code.
I have the same transmission on a different vehicle and historic codes stored in the TCM don't appear to cause a problem - I had issues with a dog chewing the harness and the TCM detecting what seemed like every possible fault, a few hours with a soldering iron and heatshrink tubing and every thing worked fine, but the codes were still there if you checked for them.
Offline kreator
  • 634
  • 15
Re: Trans issue
« Reply #7 on: July 19, 2017, 09:04:39 AM »
so you where able to repair it but not clear the codes , this week end I am pulling the harness out and look for an issue and try another TCm
Offline kreator
  • 634
  • 15
Re: Trans issue
« Reply #8 on: July 24, 2017, 11:51:46 AM »
Well got the TCM change out and now it shifts through the gears , now I just need to get the brake release power to shift it out of park to work .
Offline duke45
  • 9
Re: Trans issue
« Reply #9 on: August 07, 2017, 11:18:18 PM »
Good to hear the new TCM makes the gear works now.
