Light problems
  • 2442 Views
Offline LongRod
  • 28
Light problems
« on: March 12, 2004, 02:45:49 PM »
   I recently obtained a 94 two door, auto transmission Tracker.
None of the dashboard lights work. The domelight works as do the headlights, tail lights, turn signals, horn, side markers and other electrical components. I found the under dash fuse box and all 14 fuses are good. I'd really like to get the speedometer light working.
  With regard to the headlights, I discovered that the right side headlight isn't firmly mounted. It works and looks fine but the bottom edge swings in and out about a half inch. It's as if the top edge were connected to a hinge which may be the case. There's probably something missing that adjusts the beam angle but I need advice as to where to look and how to adjust the angle so it stays put. ???
     Thanks!
I wasn't always the dried out loser you see today; I used to be a moist and spongy loser!
Re: Light problems
« Reply #1 on: March 12, 2004, 03:40:26 PM »
check the bulbs ???
they do burn out
Offline LongRod
  • 28
Re: Light problems
« Reply #2 on: March 12, 2004, 06:46:23 PM »
check the bulbs ???
they do burn out
 LOL, good idea. I didn't think all the dash lights could possibly burn out at the same time (none of the instrument lights work) but I suppose it is possible. How difficult are the bulbs to get at? :-/
Offline 00nothing
  • 73
Re: Light problems
« Reply #3 on: March 12, 2004, 11:57:04 PM »
i know this may sound a little stupid but are they dimmed down i know i did that once i thought my dash lights weren't werking but one of my kids turned the dimmer all the way down
Offline LongRod
  • 28
Re: Light problems
« Reply #4 on: March 13, 2004, 04:42:03 AM »
  Actually that was my first thought and the first thing I checked before the fuses but the answer is no, the dimmer is turned all the way up. :'(
95XL7
Re: Light problems
« Reply #5 on: March 13, 2004, 04:47:17 AM »
did you try unplugging the dimmer switch and jumping the wires? If you have a test light check check it for power.
Offline LongRod
  • 28
Re: Light problems
« Reply #6 on: March 13, 2004, 03:48:37 PM »
  Well no actually, I hadn't thought of that. Very good idea, thanks! ;)
Re: Light problems
« Reply #7 on: March 13, 2004, 04:38:21 PM »
Well when you said "recently obtained" I thought
you may have never had dash lights since you got
the trucklet, I think there are 2 bulbs, and you have
to remove the the instrument cluster and find the
bulb holders, they twist 90* and out, to get the cluster
out, remove 4 screws 2 top, 2 under, then the 4 screws
that hold the cluster into the dash, the speedo cable
plugs in and will pull clear, replace bulbs 193s I think
but check first, and put cluster back, click speedo cable
(it's kind of a pain) and replace screws (not too tight or
they will strip the threads)
Good luck,
