engine oil compatible
  • 1738 Views
Offline rasmeidirtrider
  • 76
« on: November 23, 2017, 05:04:49 AM »
Is the 10w40 compatible to the 10w30 due to the 10w30 seems no longer available now?
'96 (07/95) US imported Sidekick Sport, 16V, 1.8L, 4 auto, 4x4, 4dr, A/C, ABS, 100K miles, VIN: JS3TD21V6T4101985, bone stock, except 215/70R/16.
Offline fordem
Re: engine oil compatible
« Reply #1 on: November 23, 2017, 05:48:21 AM »
10w30 oils are still made, if you're not seeing it on the shelf, ask for it, shop around, call the distributors...
Check your owner's manual, there should be a chart showing what grades of oil are suitable based on temperature, you'll most likely find that a 10w40 can be used across a wider range of temperatures than a 10w30 can.
  • 76
« Reply #2 on: November 23, 2017, 05:36:29 PM »
Thanks. 10w40 gets replaced in the range!
