Sidekick sport flywheel resurface - SHIM ???????
  • 6 Replies
  • 3396 Views
Offline thebanjoman
  • 72
  • ZUKIWORLD Online!
« on: December 12, 2017, 03:38:46 PM »
OK,  As part of my rebuild Im installing new clutch and need the flywheel resurfaced.
This is sidekick sport with Hydraulic clutch, no cable,.
Machinist insists that I'll need a SHIM for the flywheel after the resurface because its a hydraulic clutch, claims he'll need to make up for the amount removed.
He says he's going to take .025 off and I'll need a .025 shim.
Won't the adjustment of the hydraulic clutch make up for it?
He says he doesn't have any Suzuki listings in his books
Is a shim needed??
Re: Sidekick sport flywheel resurface - SHIM ???????
« Reply #1 on: December 12, 2017, 05:10:22 PM »
As far as I'm aware - NO.
I'm very curious as to where he expects this shim to be fitted, and would like to suggest that if he's a machinist worth his salt he can make one for you, if it's actually required.
For what it's worth, there are no adjustments on the Sidekick Sport clutch - it is self adjusting.  As the clutch linings wear, the piston in the clutch slave will gradually move further & further out of the cylinder, and you may notice an increase in pedal travel as this happens - the engagement point will shift lower over time until you'll find that the pedal is all the way down and the clutch not fully disengaged - at least, that's been my experience with the hydraulic clutch on the Grand Vitaras.
Offline thebanjoman
  • 72
  • ZUKIWORLD Online!
« Reply #2 on: December 12, 2017, 05:38:48 PM »
Which is why I ask these type of questions. He said to go between the crank and the flywheel to make up for the amount he is taking off.
In my limited knowledge of such things I agree with your information.    There is adjustment in the hydraulic 'rod'
I had to take off the 'arm' under the dash  that attaches to the clutch 'rod ' because it was bent and mangled, apparently a common occurrence.   I bent it back, beefed it up by welding the crack and doubling its width with some steel making it stronger than it ever was and fitted it with a brass bushing to also help as the bent piece was almost worn from a circle to a 'C".
The 'arm' fits over a splined  shaft so there is also adjustment there.  Taking off the 'arm' and putting it back on was just about the worst wrenching experience I have had in years.
The 'machinist' I spoke to kept referring to 'turning' and not resurfacing, this meant cutting on a lathe and not a normal resurfacing setup like I have seen in the past, so the more he spoke, the less my confidence remained.   I've not had a flywheel resurfaced in 30 years so I'm rusty in the whole process.
There are others in the area so I'll be 'getting a 2nd opinion' as they say.
« Reply #3 on: December 12, 2017, 06:20:33 PM »
First - the shim - he wants you to move the entire flywheel - with no regard for anything else, like starter engagement - he's just concerned about the clutch ...
Not quite how I would be doing it.
Second - clutch adjustment - I could be wrong - but - whilst you can shift the clutch lever/arm on the splines, I doubt it was intended to be used as an adjustment - look closely and see if you find "alignment marks" - two dots, one on the lever/arm, one on the shaft - if you do, there is only one correct position, with the two dots adjacent to one another.
Regarding your machinist - you might be surprised by what a skilled machinist can do with a lathe - the first time I had a cylinder head resurfaced it was done on a lathe, and I went from blowing out head gaskets every few weeks to never changing another gasket on that engine.  If the lathe is large enough to hold the flywheel (and that takes a decent sized lathe), and the machinist knows his stuff, I wouldn't be too bothered about the fact that he's using a lathe.
What struck me as odd earlier is that the machinist wanted to remove 0.025 in, it sounded like a lot - I've never had a flywheel that needed to have that much removed - is it badly scored or are you just doing a routine resurface because you're replacing the clutch?
Offline thebanjoman
  • 72
  • ZUKIWORLD Online!
« Reply #4 on: December 12, 2017, 06:55:32 PM »
I see where you are going with the flywheel and starter. I can understand that.
To tell if there are alignment marks on the pedal shaft I'd have to remove it.. I can't get enough of a look to tell but I think I have it close enough for working right. It was fine before I removed the transmission. I had good pedal feel.
This is just a routine maintenance for a new clutch,  I'm removing the 1.8 and putting in a 2.3 engine and upgrading to a better clutch because of the increase in potential power.   There is minimal scoring on the flywheel and it just shows what looks to me like normal wear.
Just doing what is supposed to be done when installing a new clutch.   New pressure plate, new clutch disc, with a resurfaced flywheel.
At least this is always how i was taught by my mechanic Dad that you do it all and skipping any of it is asking for trouble.
Offline thebanjoman
  • 72
  • ZUKIWORLD Online!
« Reply #5 on: December 13, 2017, 02:52:53 AM »
I've spent some additional time researching this and have come to the following conclusions.
There are essentially 4 types of clutch actuation (at least what I have found)
Full mechanical
   Pedal  to linkage  (levers, rods) to lever actuated bearing (Not related to Suzuki)
Cable - mechanical
   Pedal to cable to lever actuated bearing ( Samurai Sidekick except Sport) have this
Hydraulic mechanical
  Pedal to hydraulic line to lever actuated bearing (Sidekick Sport)
Full Hydraulic
  Pedal to hydraulic line to fluid actuated bearing  (Not related to Suzuki)
The clutch mechanism on my Sidekick sport is Hydraulic mechanical    Pedal to hydraulic cylinder that actuates the mechanical lever inside the bell housing.  Instead of cable, hydraulic fluid moves the lever.
 I believe that the reason the machinist was concerned about shimming the flywheel is for a Full Hydraulic setup where adjustment is probably not as easy.
So there should be no reason to 'shim' the flywheel for this setup as there should be sufficient adjustment in the 'plunger' on the hydraulic cylinder.
Which is probably the reason why I can't find any shims.
So I think I am set.  I just need to go back and explain this, When  I talked to the machinist we only discussed hydraulic clutch and he probably meant full hydraulic and thus his concerns about shimming.
If i'm missing the mark.. somebody help me out.
Offline thebanjoman
  • 72
  • ZUKIWORLD Online!
« Reply #6 on: December 16, 2017, 04:43:02 AM »
After all the drama, got it resurfaced. Looks good and will work just fine.
