Oil sender ~ thread and size
  • 3 Replies
  • 1717 Views
Offline sidekickyc
  • 137
  • ZUKIWORLD Online!
« on: February 02, 2018, 05:39:48 PM »
Greetings ~ I've a question ~ what size is the port where the oil sender is screwed in```
 Is it close enough to 1/8" pipe thread ~ so that a ~ 1/8" nipple can be threaded in with teflon tape ~ it won't have to come out again ```
I haven't pulled it to take a look```
Richard
Offline RBEBY
  • 21
  • BEACHIN
Re: Oil sender ~ thread and size
« Reply #1 on: February 02, 2018, 06:23:25 PM »
It's 1/8 metric, very close to 1/8" pipe, but different.
Offline sidekickyc
  • 137
  • ZUKIWORLD Online!
« Reply #2 on: February 02, 2018, 06:57:53 PM »
RBEBY ~ thanks ~ I was hoping for that rather than ~ send and wait for a sandwich adaptor``` I'll see tomorrow```
Richard
Offline fordem
« Reply #3 on: February 03, 2018, 04:54:17 AM »
There's nothing "metric" about it and you'll also never find anything metric specified in fractions - the oil sender port is 1/8" BSPT - british standard pipe tapered - it looks very similar to a 1/8" NPT (national pipe thread) but it is very slightly larger in diameter, and also has a closer thread pitch (27 tpi vs 28).
You cannot screw a 1/8" NPT male fitting into a 1/8" BSPT female port without cross threading it, but you can in most cases get a 1/8" BSPT male fitting into a 1/8" NPT port and get it to seal because of the taper on the BSPT fitting.
