2000 2.0 Crank, No start issue
  • 0 Replies
  • 1854 Views
Offline DzMiniz
« on: February 15, 2018, 10:35:06 AM »
2000 4 door 4wd auto
123k
Was driving the wife to work last week and the tracker shut off, i put it in neutral and drifted into her work.
Wouldn't start, got towed home.
Cranks, but doesn't start.
Fuel pump primes when you turn the key
No CEL's
I pulled the valve cover off to have a look at the timing chain, it looks fine, as do the gears.
I've never messed with coil on plug before, if you test it like normal plug wires, I have no spark.
From what i've read the Camshaft sensor causes intermediate cutoff. Will this cause a no start also?
