86 Sammie won’t start pumping fuel but not into carb
  • 2320 Views
Offline Hillbros907
« on: April 07, 2018, 08:50:10 PM »
I have a86 Sammi with stock motor brain box blow out got a new one installed it started rite up ran for like a min then stopped after that won’t start the motor is cranking no fire tho i tried starting it and step on the gas after about ten seconds it seem like it was trying to start a lil let go of key it would stop rite away turn key give it a sum gas it do it agian clean carb reinstalled it same thing idk wats going on needs some help
Offline Phase change
  • 199
Re: 86 Sammie won’t start pumping fuel but not into carb
« Reply #1 on: April 09, 2018, 07:42:12 AM »
Stuck carb floats, stuck needle/seat, bent carb floats, clogged filter, pinched line,
2003 Suzuki tracker 4d 5sp 2.0 “piglet”
Deleted air 4wd system, Manual hubs, 2” lift, 235/75,
Old ride: 1997 X90 “jellybean” best lil car I’ve ever had
« Reply #2 on: April 10, 2018, 04:34:39 AM »
Check whether you have fuel going to carburetor.  Back by fuel tank there is a rubber hose connecting fuel tank to fuel lines to motor, that frequently cracks.  This cracked line then draws air instead of fuel from tank.  That would be my first check before replacing fuel pump.
