Re: Rebirth of Gopher!!!!
  • 1751 Views
Offline Mac
  • 407
  • Toys, Toys, Toys
    • 1985 Suzuki Samurai
« on: March 12, 2004, 03:23:13 AM »
Not to clear on what you meant, are you saying if your go to put the shifter into fifth gear it is a neutral, the 1.6 8v or 16V what year?
Mac
Offline Mac
  • 407
  • Toys, Toys, Toys
« Reply #1 on: March 12, 2004, 03:25:03 AM »
Did you do the body lift at the same time? perhaps you don't have enough clearance for the shifter to fully engage fifth gear.
Mac
Offline Bokin
« Reply #2 on: March 12, 2004, 06:08:25 AM »
bug here at bokins: yes it is a 1.6 8 valve and it feels like nuetral when its in fith i was  told it might be the fork?and i am pretty sure i have enough through for fith  i have 1st -4th + rev? its kind of confusing?
Offline Mac
  • 407
  • Toys, Toys, Toys
« Reply #3 on: March 12, 2004, 07:21:41 AM »
You had fifth, before you swapped the motor right, then I don't think it is the fork, I would double check and make sure fifth is engaging, when I did my Body lift, I ran into the same problem and had to make some adjustments with my transfer case shifter, I could not get it into 4lo.
Mac
