1989 SIDEKICK JX SOLD
  • 1987 Views
Offline RBEBY
  • 21
  • BEACHIN
« on: June 05, 2018, 12:27:09 PM »
1989 SUZUKI SIDEKICK JX HARDTOP $7500 1.6L 5 SPEED 5.12 GEARS
bought 14.5 years ago, had been towed behind RV, had a 80k mile 1.6l from 1991 installed before I got it. It had 100k on when bought, has 120k now.
wheels, lug nuts, 4 new Discount Tire Hankook Dyna Pro RT03 31/10.50R15 109Q C1 w/ \road hazard plan (transferable)
spare wheel w/2 tires 31/10.50
old soft top w/all parts to reinstall
window tint, front & rear floor trays, 4 floor mats
last year all u joints, rear brake shoes, wheel cylinders, all rear brake hardware, new master cylinder, up graded new vented rotors, new pads & calipers to fit new rotors
new front wheel bearings, new premium warn lockout hubs, new wiper blades, new washer pump, thermostat, oil & filter in April 2018.
rebuilt ECM, platinum plugs, plug wires,valve cover gasket, adj valve lash, all ac hoses, compressor seal kit, clutch & idler bearings, expansion valve, serpentine belt
hi flow cat converter, SS Summit turbo muffler, new o2 sensor, Calmini headers & exhaust
new large clutch & pressure plate, pilot & throw out bearings, clutch cable
alarm w/ 2 remotes & power door lock kit, all 3 doors, 4 stainless steel driving lights w/relays wiring & switch
camber bolts, Calmini 3" body lift, 3" suspension lift, steering stabilizer, idler arm stabilizer, F&R spring spacers, OME front springs, gas tank lift.
Calmini front skid plate, front winch bumper, rear tire carrier bumper, roof rack.
All take off parts in a box, spare 1.6l engine (needs crank) ac comp, starter, ex manifolds, factory spare wheel & tire, parts manuals, 1989 FACTORY SHOP MANUAL,
Chilton shop manual, wiring diagram, predelivery inspection seminar manual, sidekick introduction seminar manual
7/29/2018 NEW BXL-65-675CCA 84 MONTH MOTORCRAFT BATTERY
CUSTOM 3RD BRAKE LIGHT IN SPARE TIRE
REAR HITCH, FRONT HITCH
« Last Edit: September 14, 2018, 01:56:19 PM by RBEBY »
  • 6598
  • 68
Re: 1989 SUZUKI SIDEKICK JX FORSALE
« Reply #1 on: June 06, 2018, 07:55:07 PM »
Looks great! Good luck with your sale... Love the brown interior. (it's like mine.) :)
Re: 1989 SIDEKICK JX FOR SALE
« Reply #2 on: July 27, 2018, 10:00:22 AM »
price??
