RRO Rocksteady lift & camber
  • 17 Replies
  • 4328 Views
Offline chrisvitarasport94
  • 228
« on: March 04, 2004, 07:49:17 AM »
forgive me, I know this'll have been asked before, but someone may have an up to date experience. I'm in the UK, with a'94 3dr Vitara Sport, and so have locally sourced +1.5" Ironman springs with 1" (imported) RRO spacers, and +2" strut spacers on standard struts. Fitted 6 months ago, the camber looks just about OK but I feel I'd like to do something about it as minor tyre wear is starting to show ( it could just be truning scrub. I've seen pics of the mods to the lower end of the strut, and heard about elongating the top holes inwards by 1cm. But how do RRO accomodate this?? Are their OldManEmu strut top mount off-set???? If so I might bite the bullet and import a set. any ideas please?
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: RRO Rocksteady lift & camber
« Reply #1 on: March 04, 2004, 09:12:06 AM »
Did you have it alligned after your install? The angles change massively from a mod like this. 90% of tire wear is from toe. OME strut does not have a camber change from stock. Ive heard people claim this but it is false.
To elongate the upper hole use some type of drill or dremmel type tool to oval the hole inward.
Mike
  • 228
« Reply #2 on: March 04, 2004, 05:05:38 PM »
no I didn't get a test done as the wheel still looked upright. I understand the geometry involved, and guessed the effective movement was within the ususal range of movement available. I don't have a toe in / out problem as far as I know.
« Reply #3 on: March 04, 2004, 10:49:20 PM »
I had the toe-in/toe out checked on my 2" spring lift after it was fitted and it was OK, I still get uneven tyre wear due to the camber change. I don't see that you can lift it 2.5" without a big camber change. The OME lift may still be within spec but adding the spacers (which are not OME) has got to have an effect.
Offline jagular7
  • 1026
  • Jagular7
« Reply #4 on: March 05, 2004, 08:09:23 AM »
Where the wear comes in is during the cycling of the suspension, up & down. When stock, the change in toe and camber is not drastic. The changes have a somewhat smooth slope to it (if you placed a graph of change over spindle travel) at first and as the farther you travel the greater the slope becomes. Now if you already start on the middle of the travel (measured as a height difference between centerlines of axis and axle), the change in the slope is drastic and gets worst.
I hope I give you some understanding. Drop brackets help in this department as the geometry between front suspension and axle components remain relatively the same.
Lenexa, KS
Offline zookiemike
  • 474
  • $,reppin Michigan,$
« Reply #5 on: March 05, 2004, 10:31:56 AM »
Ok the anser is no the ome struts do not have adjustment and no the camber is not ok. I had to get a camber corection kit for mine.
Offline Mikerpm4x4
  • 2875
    • www.rpm4x4.com
« Reply #6 on: March 05, 2004, 02:47:11 PM »
I can assure you that the allignment has changed. Ive never seen an allignment still be good after spacers.
Mike
  • 228
« Reply #7 on: March 05, 2004, 06:20:33 PM »
Zookiemike - a camber correction kit sounds exactly what I need - where can I get one? what's it include / involve ? did it work?
« Last Edit: March 05, 2004, 06:21:04 PM by chrisvitarasport94 »
Offline zookiemike
  • 474
« Reply #8 on: March 05, 2004, 07:18:32 PM »
Yeah it worked great it included / involved some ecentrec bolts and some plastic things that went in the two lower strut holes. I got them at car quest for like $20 or somthing like that?
  • 228
« Reply #9 on: March 07, 2004, 08:17:45 AM »
looks like I've found a solution at Speciality Products in the US - see www.specprod.com web site - with offset cam bolts in the top hole of the lower strut mount, with +/- 2 deg adjustment.
now I need to know the standard camber settings that I'm aiming to get back to .. can anyone advise me please?
« Last Edit: March 07, 2004, 08:23:22 AM by chrisvitarasport94 »
« Reply #10 on: March 07, 2004, 10:41:14 PM »
For camber sttings take a look on my website under tech info, vitara. IIRC it is 0 degrees 30 mins.
http://www.rhinoman.org
Offline Vit-A-Jim
  • 47
« Reply #11 on: March 09, 2004, 09:10:31 AM »
Hi Guys,
I have a kick '93 with RROs 2.5"suspension lift, with OME and Spacers, and 2" body lift. After the installation the front wheels where like that \  /.  So after a long search on the net I found the following : http://www.autospeed.com/cgi-bin/browse.cgi?category=645&product=1004300113&sc_add=1004300113&
This is Camber Correction Kit from an Australlian company. It took me 2 weeks to come (to Greece) and now my front wheels are exactly at the factory setting like nothing has changed.
I hope this helped.
Road is... The boring part that joins two mud tracks.
  • 228
« Reply #12 on: March 09, 2004, 05:02:51 PM »
do I guess that those are offset bushes to fit into to top arm?
Offline zookiemike
  • 474
« Reply #13 on: March 09, 2004, 05:40:01 PM »
I'd go to a auto parts store and look for the bolts befor you go and mess with the A arm bushings :-/
  • 228
« Reply #14 on: March 10, 2004, 02:55:00 AM »
 yeah, that's what my mechanic has told me - the offset bolts can adjust + / - 1.75 deg, which should be enough. If not I can add these bushes later, and then the adjustable element of the bolt can be reset I guess.
PS - I parked next to a stock version of my ' Sport  today :) :) :) !!
« Last Edit: March 10, 2004, 02:55:19 AM by chrisvitarasport94 »
