Zuki Will Not Start????
Alaska101
67
The Original !! What started it all.
March 01, 2004, 12:05:32 PM »
Any Ideas?? I have not checked spark or gas but it is too dark out now, so I though I would ask if there are any comon things. I turned it off an the about 2 min. I tryed to start it all I got was Starter and nothing else.
Thanx
1979 Lj81 Truck. Named REP-TAR! (Green thing from the rugrats)
Mod's include:
2001 GV frame w/ 2.0l dohc, and auto trany
Snorkel, 31x10.5 R15 tyres, Soon to be 35's
, also will have a dump box!!
HotRod
4334
2
95 Tracker
Re: Zuki Will Not Start????
March 01, 2004, 01:46:36 PM »
whats your milage? It seems to be a popular answer but does it seem to turn over quicker now?
First guess would be timing belt or a silly fuse.
WV-TrailRunner
13
it RUNS!
March 11, 2004, 02:53:51 PM »
Turn your key on... get you a 17mm socket... and turn the crank slowly with the coil unhooked... listen for the injectors to open and shut... if you dont hear anything then you may have a broken timing belt or a bad connection at the distributor where the wires plug in at the bottom... check the ground near the back... or take the valve cover off and see if the cam turns.... good luck to ya cause i've been there not too long ago...
1995 Sidekick 1.6L 16v G16B
140,000 miles and counting...
NightTalonDragon|removethispart|@charter.net
zuktinter
57
Reply #3 on:
January 23, 2009, 09:45:20 AM »
if it is carburated sray some starting fiulid in the carb and see if it starts,if so it must not be getting gas.
check for spark.
take off oil cap and turn over to see if cam and valves or turning.
90camozuki
90
Go Hard or Go Home!!
Reply #4 on:
January 23, 2009, 10:18:57 AM »
this post was from 2004. I hope he has got it cranked by now.......
1997 Jeep Cherokee 2" lift, 31s, snorkel, arb bumper, roof rack, piaa lights, soon to be 4.5" super flex lift.
1973 Dodge Charger, fully restored, banana yellow...
2001 Dodge Ram 2500...work truck...
2006 Honda Pilot...wifes ride...
1998 Pontiac Grand Prix GT....Gas saver.......
zuktinter
57
Reply #5 on:
January 23, 2009, 01:31:54 PM »
Lol guess I didn't notice the date.
