Technical Discussion - Performance / Modify
96/97 aftermarket double din
SoCal87
28
ZUKIWORLD Online!
August 26, 2018, 01:19:49 AM »
Does anyone know if a aftermarket double din will fit without needing a bezel or modified brackets?
1990 Geo Tracker LSI 4x4 2dr
1996 Geo Tracker LSI 4x4 4dr
Ridjobradi
674
6
Re: 96/97 aftermarket double din
August 26, 2018, 01:46:21 AM »
The double DIN fits with a bezel kit. They're cheap and easy to get. It will be a universal type bezel that will require you to cut some tabs. Order the kit when you order the wiring adapter.
trkrpwr
23
3
ZUKIWORLD Online!
August 26, 2018, 05:07:20 AM »
I've got a 98 that had factory double din and I swapped it out with just a harness adapter. A bezel kit would provide a more finished look but, depending on the face plate, it may not be needed.
