weak drive train
  • 15 Replies
  • 4469 Views
Offline standog
  • 111
weak drive train
« on: March 07, 2004, 01:18:06 PM »
I just read the artical about changing from auto to manual hubs in a zukiworld artical. How weak is the drive train on the new Vitara's?  Is the shift on the fly really that weak of a part? I do not do anything crazy but want to have confidence in my truck when I do go offroad. I hope that I am just overreacting  and just need a little reasurance.
Thanks.
Clay
Offline idaholwb
  • 772
Re: weak drive train
« Reply #1 on: March 07, 2004, 03:04:07 PM »
 All it means is that instead of having manual or automatic hubs, it has what are called drive flanges. They just have a steel plate that is splined on the inside. The half shafts, differential, and front driveline spin just like having the hubs locked in. There is no weakness about it. The main problem that I can see, is fuel economy reduced. If you have any concerns about the flange vs hub theory, just plain and simple, change the flanges to either the sammy or trackick hubs.
97 Sport
265/70-16s
2" lift
2.0 swap
« Reply #2 on: March 07, 2004, 03:34:34 PM »
On the same kind of topic, would the kick auto hubs fit a sammy with out mods?  just for street driving in the winter time!
Offline jagular7
  • 1026
  • Jagular7
« Reply #3 on: March 08, 2004, 02:05:33 PM »
I have close-up pics of this in my webshots of when I did the manual hub install. Other thing to note about using manual lock-outs, if you do break something in the front axle, atleast you can disconnect the rotation of the axle shaft from the rotating tire. The manual hubs give this. If you still had the drive flanges, the front axle would rotate with the tire rotation.
Lenexa, KS
Offline idaholwb
  • 772
« Reply #4 on: March 08, 2004, 03:54:25 PM »
 Yes the kick auto hubs would work on a sammy, but I would never recommend using the auto hubs on anything. The autos are junk, but if you must use them..... :o
97 Sport
265/70-16s
2" lift
2.0 swap
Offline sarmeier
  • 43
« Reply #5 on: March 09, 2004, 01:19:51 AM »
Jagular7,
Is there a specific reason or reasons you went with Super Wich vs Warn hubs?  I am looking at doing the same conversion but don't know which manual hub to use.
Thanks
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #6 on: March 09, 2004, 02:56:20 AM »
I went from auto hubs to Warn premium manual hubs.
I did it because Warn also sells "hub fuses" for their premium hubs.
The idea of the hub fuse, is that IT grenades, instead of something else in your drive-train.  They're pretty easy to replace, and cost about $20 per pair.
Still haven't shatered one yet.  Maybe at Moab...
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
« Reply #7 on: March 09, 2004, 03:57:13 AM »
Bobzuki,
Keep us updated on the Fuses. I have been wondering if they will blow apart before a CV :-/ And the last time I broke a half shaft, I blew apart the hub also >:( I'm going to run my stock hub untill I get more info on the Warn fuses.
Offline jagular7
  • 1026
  • Jagular7
« Reply #8 on: March 09, 2004, 12:00:08 PM »
Jagular7,
Thanks
I got a set of Warns, they were new, but ran into a slight snag when installing them. I think the pics are in the album. I belong to a local 4wd club here in KC. We have a truck sponsor (ass. manager is part of club). I get things for jobber cost. I got a set of Superwinchs. These installed rather easy. Besides, the supers are guaranteed for life with me. Simple enough.
I was able to exchange the Warn's at my local Advance, so I have a good set in the garage collecting dust. Just haven't gotten around to posting to Ebay for the sale. I've placed it before in the for sale section here.
Lenexa, KS
Offline standog
  • 111
« Reply #9 on: March 09, 2004, 09:56:02 PM »
Jagular7, How hard was the swap. I am interested in doing it on my 03 Vit. Anything special needed? Do you happen to have the par # for the superwinch hubs.
Thanks
Clay
« Last Edit: March 09, 2004, 10:01:00 PM by standog »
Offline sarmeier
  • 43
« Reply #10 on: March 10, 2004, 01:17:03 AM »
Jagular7,
I'm interested in the Warn hubs you have.  But what problems did you have with them?
Thanks
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #11 on: March 10, 2004, 07:48:31 AM »
Has anyone really had a problem with the stock one's??
I'm going to keep them untill I have a real problem with them.  I do need to get to the junk yard and get a spair.
32 MTR's Warn 8000i
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #12 on: March 10, 2004, 07:54:59 AM »
Well, I've HEARD about people having trouble with the auto hubs disengaging, which is why I went to manuals in the first place, and the fuses on the Warn premium hubs is what swayed me in that direction.
Bob
Offline jagular7
  • 1026
  • Jagular7
« Reply #13 on: March 10, 2004, 01:09:00 PM »
Thanks
Clay
Swap is as easy in the pics. The pics show basically the step by step procedure. Only thing necessary is a metric socket for the drive flange bolts (13mm IIRC), 1/4" hex key for Superwinch lockout hubs, and can't recall the hex key of the bolts. That's basically it. (I bought the hubs back in 11/11 and I thought I provided some info here.)
As for p/n 400538 is what is on the receipt.
Lenexa, KS
Offline jagular7
  • 1026
  • Jagular7
« Reply #14 on: March 10, 2004, 01:13:51 PM »
Jagular7,
Thanks
Only trouble I had was with the alignment of the teeth in the housing and when I tried to force, the plastic lip to the cover cracked. I did the install back near 11/11. Check in the old messages for better details.
Not everyone had the trouble I had with the Warns. I was able to replace them with a new set. These are setting on the shelf currently.
Lenexa, KS
