Ready for some more pics!?
  • 12 Replies
  • 4186 Views
Offline hcgalvin
  • 1695
    • Granite Path
« on: March 06, 2004, 05:30:43 PM »
http://www.whitepineclub.com/members/kd7hcg/pictures/SAS/SASday6/index.html
Here's a couple highlights:
Steering:
Body lift OFF and me all dirty next to it:
;D
Heather Galvin
Re: Ready for some more pics!?
« Reply #1 on: March 06, 2004, 05:43:11 PM »
That is looking Sweeeet!!
Offline Kreg
  • 795
    • Island 4x4
« Reply #2 on: March 06, 2004, 05:53:11 PM »
Looking good!
How much lower will the truck sit when the springs are under load?
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #3 on: March 06, 2004, 09:41:24 PM »
I like the way you made the front spring purches with the 2" receiver in it.  It's one of the best set ups I've seen with a SAS.
So, will it be able to leave the garage or do you have to air down the tires?  ;D
32 MTR's Warn 8000i
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
« Reply #4 on: March 06, 2004, 11:48:17 PM »
LOOKING KICK AZZ .........HEATHER BTW YOU NEED TO DARKEN THE TYPE IN THAT LINK A BIT..LITTLE HARD TO READ ON THE RIGHT SIDE IN THE TREE'S  ;D  MATTY D.  8)
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
« Reply #5 on: March 07, 2004, 02:34:48 AM »
Very good work Heather!!!!
And Kreg, top less girls on your name are SO COOOOL!
Could you make the same things with my name?
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #6 on: March 07, 2004, 03:40:00 AM »
Thanks!
Yeah, I know... we are going to be changing the main theme to the site soon since spring is coming up, so it will look better then.
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #7 on: March 07, 2004, 03:40:54 AM »
Thanks for the comment about the front hitch, it was pretty ingenious. So far, it looks like we will be able to "sqeak" out of the garage.  ;)
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
« Reply #8 on: March 07, 2004, 03:42:34 AM »
Looking good!
Not too much lower, my truck has a small stinkbug stance right now, it sits about 1 1/2 inches higher in the back. When Nate sat on the bumper, it came down to level.
We still have to put shocks in the back. We are going with some that have 16" comp and 28" ext.
Heather Galvin
lucszuk
« Reply #9 on: March 07, 2004, 08:53:02 AM »
thats higher than my zuk, now i have competition!!!( in case u didnt know cause i never said i have a combined 14 inches of lift.....)
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #10 on: March 07, 2004, 11:27:10 AM »
Heather, Is the front loaded in that pic? Also are you planning on running a panhard bar? If that is loaded you might have a problem with bump steer. :-/  Looking good. Keep us posted with progress.
Mike
« Reply #11 on: March 07, 2004, 03:53:20 PM »
Looks awesome ;)
We need more pics!!! 8)
Offline jagular7
  • 1026
  • Jagular7
« Reply #12 on: March 08, 2004, 02:08:47 PM »
Looks great Heather. Though went to your website and saw even more pics.
Saw one with body lift off, adding bumper, etc up front. Those shackles look like they'll be used more as a feeler. Is this just the picture or is this a real concern?
I know of several Samis with rollers on their shackles. The roller hits first and rotates upward. The bolt is the spring eye bolt. Only 1 situation when the spring bent rather than roller rolling. It was more of the undercut than anything else. Bent the main spring and the 2 longer ones. Otherwise, back on the road. Getting it home was a little tricky, kept on wanting to turn right....
Lenexa, KS
