GV front 3rd housing part number?
  • 18 Replies
  • 5270 Views
Offline Kreg
  • 795
    • Island 4x4
« on: March 01, 2004, 10:09:52 AM »
Hey does anyone know the part number for the "steel" front 3rd housing for the GV?
Will any year of the GV third bolt onto my axel housing?
I went to the Suzuki dealer today and the guy at the parts desk was as useless as a tit on a bull. So I told him that I would go find the part number for him so he didnt have to do his job  :P
TIA
  • 6602
  • 69
Re: GV front 3rd housing part number?
« Reply #1 on: March 01, 2004, 10:14:42 AM »
TIA
Do a search for XL.7 or XL-7 3rd member that is the one you want it is steel AND beefier than the GV. The crossmember mount is the only difference but don't worry it's better....
Here it is: :)
http://www.zukiworld.com/cgi/yabb/YaBB.pl?board=suzuki_talk;action=display;num=1072585510;start=5#5
Good Luck, -Eric
Offline Kreg
  • 795
    • Island 4x4
« Reply #2 on: March 01, 2004, 11:07:45 AM »
Sweet, thanks bud.  8)
  • 6602
  • 69
« Reply #3 on: March 02, 2004, 12:32:53 AM »
No Problem... You may want to get the 3rd member to crossmember mounting system as well when your there. Or, you could junk yard it but you'll need the different mounting bracket.
Good Luck, Eric
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #4 on: March 02, 2004, 12:42:57 AM »
Huh, I didn't know about the XL-7 front carrier, and the "snout mount".  I did put a Grand Vitara (manual transmission) steel carrier in, with the same mount as the Sidekick aluminum carrier.  When I broke my front carrier, the aluminum lug that the mount connects to, sheared right off.  :o  I figured the steel lug wouldn't have this problem!
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
« Reply #5 on: March 02, 2004, 01:25:44 AM »
Bobzuki,
This is what the XL-7 mount looks like.
Offline Yankee Tim
  • 431
  • Who says a GV is a grocery getter?
    • Yankee Off-Road
« Reply #6 on: March 02, 2004, 11:51:57 AM »
Uhh, who are you and what did you do with the Bob I know?
Bob, think back a bit with me.  It's 2002, we're in Moab, the XL7 is about a year old,  You standing with me, next to my busted GV, looking at the aluminum XL7 diff that I had in my GV, noting the big beefy center mount (the one that cause me such grief finding) and it's oversized mounting boss that didn't break off, but instead, let the entire pig crack open like an egg?
Yeah, you knew about it.  ;D ::)
I was telling everyone at the time that the XL7 had an improved mounting system.  However the simple concept of steel pigs, which I learned of before AND STILL opted to choose the XL7 soda can, still eluded me.
Now everything it steel and no problems.
BTW- I'll be kicking in Saturday night or Sunday morning, depends if I have a co-pilot or I drive non-stop alone.
Yankee Tim
Offline Kreg
  • 795
    • Island 4x4
« Reply #7 on: March 03, 2004, 09:13:17 AM »
Ok I called the guy from the suzuki dealer and gave him the part number.  He said that there was an automatic and a standard carrier?
Which one do I get?
Maybe he was talking about buying the whole 3rd itself (gears and all) because I don’t see why there would be a different carrier.
I also asked him about the mounting brackets and he asked me what year I wanted.
Heh why can't anything be simple? I thought the part number for the housing would be a straight shot, but they found a way to make things complicated.
Any help would be grateful. I just want to make sure I get the right parts.
TIA
« Reply #8 on: March 03, 2004, 09:59:21 AM »
The manual one is steel and the auto is alumanimamama
Offline Kreg
  • 795
    • Island 4x4
« Reply #9 on: March 03, 2004, 12:06:37 PM »
Ok, and will any mounting system work on the Steel one?
Do I need to get a specific year?
« Reply #10 on: March 03, 2004, 01:09:02 PM »
Thats a good Question. The one I got had the mount Zig posted, so I redrilled and filed it a little thinner  to make the old mount fit.
Offline Kreg
  • 795
    • Island 4x4
« Reply #11 on: March 03, 2004, 01:28:52 PM »
Sorry for al lthe questions, but heres a few more...  :P
So you didnt use the new mount and just used your calmini one?
That brings up another question. Wasnt the Calmini mount designed to make the diff sit lower than stock?
Does the XL7 mount make the diff sit too high? or will that even be a problem?
« Reply #12 on: March 03, 2004, 09:05:59 PM »
The GV steel mount is like your calmini and/or stock mount, but steel (a tab with a couple of holes for the bolts to go through. The XL-7 is a large flat peice that bolts streight into the housing (not through a tab)
GV
XL-7
The XL-7 rubber bushing mount allowed enough 'twist' in it to line up good. I did need to do a bit-o-gringage on the bracket base.
If you have not seen them yet, check out the two Zukiworld articles below. They will probably help.
http://www.zukiworld.com/month_090103/feature_sidekickdrivetrainimprovements.htm
http://www.zukiworld.com/month_110103/feature_zigsbeef.htm
« Last Edit: March 03, 2004, 09:06:56 PM by Zukipilot »
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #13 on: March 04, 2004, 12:33:44 AM »
Ohh, yeah...  Forgot about that, and now, I wish I woulda remembered that bit about the beefier mount.  I went with a GV manual carrier, so I have all steel, but I still have the original mount.  Well, time will tell - I know the mount is stronger than the aluminum tab on the old carrier, that I sheared completely off!
One other thing, that I'm not seeing in these install instructions - I put mine all together, and started adding diff fluid, and it came ruinning out on the floor!  There's a hole in the GV carrier - I have no idea what it's for - it's not threaded.  I just plugged it with a plastic cap & some RTV.  Here's a pic of the red cap in the carrier.
« Last Edit: March 04, 2004, 01:41:49 AM by Bobzooki »
Bob
« Reply #14 on: March 04, 2004, 01:26:09 AM »
I have not heard of any one having any trouble with the GV mount ;) I went with the XL-7 after some prodding by Eric and Yankee Tim. I like to do different stuff any way ::) I almost did the leaking oil thing too. Luckily I slid under the Kick to show a friend my new Anvil and saw the hole that I forgot to plug.  :P
