Birfield Rings
  • 4113 Views
Offline shoyrtt
  • 161
Birfield Rings
« on: March 01, 2004, 09:26:39 AM »
I am about to lock my 86 Samurai's front axel. I am running the stock motor, 6:1 gears, coil suspension with 35 MTRs. I hear the birfields with a locked front end break constantly. Rocky Road Outfitters lists "Birfield Rings" for $99 a pair. Has anyone used these rings or a competitor's? How easy are they to install? Thanks for the help.
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: Birfield Rings
« Reply #1 on: March 01, 2004, 01:26:51 PM »
I'm getting ready to get a pair of rings. In most cases you need to press them on the bell of the joint and you may have to grind the inside of the knuckle a little. Usually the rings come with directions where to grind. I think I'm going with the ones from Spidertrax.http://www.spidertrax.com/
Let us know how you do with the assembly or carnage of broken axles. ;)
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
Re: Birfield Rings
« Reply #2 on: March 01, 2004, 01:33:37 PM »
Heres what the sami people in our club have had happen. If you put the berf rings on then you break the axle at the spider gears. In case thats never happened, its a way worse break. :( Calmini and I think Trail Tough sell stronger axles. A couple guys have bought the Calmini shafts and put Berf rings on while running 35 MTRs. So far so good.
Mike
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
Re: Birfield Rings
« Reply #3 on: March 01, 2004, 08:54:55 PM »
RRO sells the Spidertrax rings. They are the same product  ;)
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
Offline Yankee Tim
  • 431
  • Who says a GV is a grocery getter?
    • Yankee Off-Road
Re: Birfield Rings
« Reply #4 on: March 02, 2004, 12:17:54 PM »
I've done a lot of "research" on the whole ring thing. I don't intend to piss anyone off, as I like Eddie and Tom, Steve and Tim all. Here I go.
I know of 3 "rings" on the market.  Spidertrax, Calmini and Breeze.  Spidertrax and Calmini are $99/pair.  Breeze are $60 a pair.
Basically,  when extreme force is applied to a stock birf, it can expand.  When this happens, the outer "bell" can crack and break apart.  Typically, this break occurs when the CV is turned to its operating limit and at the thinnest part on the bell where the machining for the balls are.  Like ripping a telephone book, when the crack starts there, it quickly grows down the bell until it reaches thicker material and stops.  By this time, the birf and usually the axle is toast.  As a note, even the manufacture left a ridge near this edge on the bell to add some more strength to the area.
Now Spidertrax hit the market first, I believe.  Their ring is applied from the stub end, and is pressed on.  There is some material the goes over the stock reinforcement ridge, and helps reduce the bell expansion.  This is the best bet for someone without machine skills or access to a machinist.
Next came the Calmini "Cup".  This ring take another approach.  First, the stock ridge must be precision machined off.  Then a ring, or Cup is pressed on from the bell side.  This not only adds more material to the location of the stock ridge, but also towards the thinnest part of the bell, where the cracks start.  IMHO, this is the best place to add reinforcement.  If you can find a good machine shop, this is the way I would recommend to go.
Last to enter the "ring" was Breeze.  These are installed the same way as the Spidertrax rings, but does not add any more reinforcement to the stock ridge.  IMHO, this ring least reinforces the area that needs it most.
Next, add a set of 26spline moly inner shafts with 26spline sidegears and you should have a much improved stock axle.  Remember, if it's not Zook, it's puke. ;D
Yankee Tim
Offline shoyrtt
  • 161
Re: Birfield Rings
« Reply #5 on: March 03, 2004, 03:36:40 AM »
Thanks for the advise! Now it looks like time open the wallet again. :P
