Black Knight Lift is on . . . Extra parts?
  • 2728 Views
Offline nomaad
  • 179
  • I wanna go!!
« on: February 29, 2004, 10:13:03 AM »
Well, I got it on. Once the weight was on it all came into line. I do have 2 parts I did not see mentioned in the instructions though. One flat steel piece about 6" long with a slight kick in it. Then a steel tube about 10" long. Do you happen to know where these go? Also has was the alignment after?
Offline jagular7
  • 1026
  • Jagular7
Re: Black Knight Lift is on . . . Extra parts?
« Reply #1 on: February 29, 2004, 11:10:20 AM »
Got any pics of the install and final install? Any specific measurements from stock to lift comparison with same tires?
Lenexa, KS
Offline nomaad
  • 179
  • I wanna go!!
« Reply #2 on: February 29, 2004, 10:44:54 PM »
Well, I had this huge plan to take pics of every item going in as the instructions only had about 6 images. To me for a non-front end guy, some of it was a little hard to follow. There are a couple of sequence that are out of order as well. I am planning on taking pics though when I go back in this weekend to re-torque everything. I will post them then.
At this point it doesn't seem any taller to me. I had the RR coil spacers on beforehand and had put the EZ cam bolt in the strut tower. Well I am assuming the longer control arms are a fix for the camber problem and the strut is now needing that standard bolt back. So, needless to say, the camber is way out and low riding. I am taking it in to get the camber and the toe done today, as well as straighting the tie rods so the steering wheel sits straight. I should have counted the turns or something. Anwho, all in all, a weekend of fun and tool buying. I will post some pics later. I still need to figure out where there other 2 parts should go.
Offline stingerx
  • 43
  • THE WAY A ZR-2 WAS ORIGINALLY DESIGNED
« Reply #3 on: March 01, 2004, 01:24:23 AM »
ive got the calmini 2.5 lift and while going through the parts i found a 10 inch brake line extension.  perhaps these made it to the boxes by mistake.  however can some one clarify what calmini means by the strut tower modification of grinding 1/8 inch inward toward the center.  is the hole supposed to be notched?  im planning on installing the kit this weekend.
« Last Edit: March 01, 2004, 02:39:07 AM by stingerx »
Offline blacknight
  • 987
    • Gonzookin
« Reply #4 on: March 01, 2004, 03:27:21 AM »
If you have an xl-7 the flat pice is for the GV  but the steel tube you got me on that one.  A pic would help.
George
Offline nomaad
  • 179
  • I wanna go!!
« Reply #5 on: March 01, 2004, 06:57:16 AM »
Alright guys, talked to Steve at Clamini. Found out that the tubing is a brake line extension for the rear line. And flat steel piece is for XL's and GV's that have rear load sensing or something like that??? Can't remember exactly, but I don't need it . . .
I will probably wait til this weekend to put on the brake line when I am checking out the nuts and bolts of the install.
Thanks guys for ALL the help!! I got the truck back front alignment shop and it looks awesome. Even with the 235/70/16s  it still has a much better stance than with just the spacers. I am pleased . . .
