will nine inches.....
  • 15 Replies
  • 4570 Views
lucszuk
« on: February 27, 2004, 11:28:17 AM »
will nine inches of lift clear 34 ltb's im justr planning ahead i lan to do a 6 inch spoa and a 3 inch body lift and how much gearing is needed for 34's?
Offline TomKat
  • 211
Re: will nine inches.....
« Reply #1 on: February 27, 2004, 01:56:59 PM »
Man, your spring over alone will clear the 34's without the body lift. :o as for gearing, what is your intended use? Rockcrawling, mud, both? Pure rockcrawling needs low, low gearing(t-case and diffs), mud requires some wheelspin so anything more that a GRS 1 or equivalent is almost too much.
« Last Edit: February 27, 2004, 01:59:26 PM by TomKat »
88.5 Sammy,YJ's,33's,Yota axles,4.9-1 'case,dents and rust...
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #2 on: February 27, 2004, 02:55:08 PM »
My wife says nine inches is fine!  ::)
Mike
zookpuke
« Reply #3 on: February 27, 2004, 03:20:34 PM »
 1) samurai or tracker
2) what type of driving
3) what motor do you have
4) I am currently selling my 33 13.50 ltb tires because they are very heavy (power loss) and even after they warm up they are the WORSE driving POS i have ever owned . they work great in mud if you run them at 3 p.s.iyou will probably need beadlocks .
Offline Kreg
  • 795
    • Island 4x4
« Reply #4 on: February 27, 2004, 03:34:31 PM »
Dont build your truck up too high.
A truck with a lower center of gravity that "works" to climb up rocks is better than a skyscraper that has a very high center of gravity.
If the weight of your engine/tranny sits up to high your truck will be unstable and it will bounce around when you have to hit the loud pedal.
If I were you I wouldnt put the body lift in.  There are plenty of sammys around here running suspension lifts only and they can fit big tires.
« Reply #5 on: February 27, 2004, 03:41:20 PM »
I love the LTBs, I got the same size, and sure they are
not a street tire, they kick ass offroad tho, that's what
I bought them for, I rip up the roads on 30 or 31 used
tires on my stock rims.
And 3 PSI that's way over inflated offroad, last time I
aired down, the low pressure wouldn't register ANY Pressure
worked great, you should see everybody looking and
saying "gawd look at the tires on that Suzuki.. "
;D ;D ;D ;D ;D ;D ;D
They ain't seen nothin like this out here in the West,
Me, I think they are starting to look too small  ;D ;D ;D
Offline nc_zuk
  • 406
  • Back in North Carolina
    • www.samurai4x.com
« Reply #6 on: February 28, 2004, 12:25:07 AM »
Well that statement can be true if he doesn't have a lot of flex and he moves his axles a bit forward and a bit rearward (ie YJ's).  I have 8 inches of lift and a very flexy setup and I have a hard time keeping the 33 boggers outta the wheelwells in the front. Heck, 33 Boggers are really 32 inches anyway. Add that to the fact that I run 0 psi on the trail making them even smaller. I think in order to fit those 34's you are gonna have to trim some sheetmetal or make some bumpstops if you only do the SPOA. Just my .02  ;)
www.Zuwharrie.com[/url]
Where the road ends........... Zuwharrie begins !!!
zookpuke
« Reply #7 on: February 28, 2004, 12:27:23 AM »
 I totally agree with wildgoody about the off road use of ltb tires . i also put on different set on after trail use 33" mtr .  I live in the N.W  anything less than 3 p.s.i unless you are in the snow here is asking for trouble . too much sharp rock mixed in with slick mud.
curious wildgoody how much does your track/kick weigh  my sami weigh 2,800 with out me in it.
do agree the 33" are starting to look alittle small
lucszuk
« Reply #8 on: February 28, 2004, 11:04:11 AM »
mud moslty i have 31 lbs already so i know wat im doing and i have the 1.3 that is hoopped (i cant find eanything else to do to it) and im using 4:62 r&p's
lucszuk
« Reply #9 on: February 28, 2004, 11:05:43 AM »
i missed one of them
i already did do a body lift lol it was mny first mod !! !!CHEAP!!!
lucszuk
« Reply #10 on: February 28, 2004, 11:41:43 AM »
are genaral tire's mt grabber's any good i might get em for my lj its in need of some new shoes
Offline TomKat
  • 211
« Reply #11 on: February 28, 2004, 12:32:13 PM »
 I have 8 inches of lift and a very flexy setup and I have a hard time keeping the 33 boggers outta the wheelwells in the front. )
May need bumpstops set a bit lower? I have wheeled with Sammy's on SPOA YJ's properly bumpstopped on 34 LTB's and they worked real nice. Couple inches of uptravel is all that's needed. Once a bumstop hits, the suspension, if flexy enough, will cantilever around the bumpstop.
zookpuke
« Reply #12 on: February 28, 2004, 02:57:46 PM »
 try and help with gearing question ihave 4.62 r/p with trail tough 6.4 t/c gears with 1.6 16v . low range is excellent   , i know with same set up you woud have no problem turnig up to 35". mine is a little low for highway speeds (65 to 70) .
hope this helps . curious if you know how heavy your sami is .
« Reply #13 on: February 28, 2004, 06:22:26 PM »
Well the Kick weighs in at 2500, with
Swampers and a full tank. 2800?? you
must have all the goodies   :)
Offline nc_zuk
  • 406
    • www.samurai4x.com
« Reply #14 on: February 29, 2004, 12:01:33 PM »
Yea, bump stops aren't all that easy to put on a coil suspension. Though. My trail partner has a SPOA with Trail tough missing link setup and he stuffs 33's all day long. I guess bumpstops would definately help him out as well.  ;)
