Tracker front diff question
  • 10 Replies
  • 3354 Views
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« on: February 25, 2004, 10:51:29 AM »
ok, got 2 front pigs, one with a bad housing and good gears, and one with good housing and bad gears... need to switch em... how does the drivers side inner shaft come out of the housing?? I got the housing out, got the carrier unbolted and it moves a bit but not all the way out, I just need to get that shaft out... Thanks in advance for your help.
98 SFA Explorer - D44 front, 8.8 rear both locked on 35's, Man. T-case, Warn XD9000i
94 Tracker  Toy locked axles 5.29 r/p's, toy steering, 4.24 t-case, 35" MT's, YJ leafs, warn 9500hs
Offline Kreg
  • 795
    • Island 4x4
Re: Tracker front diff question
« Reply #1 on: February 25, 2004, 11:08:28 AM »
you might need a slide hammer to take it out, just like the ones in the rear axle but I'm not possitive.
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #2 on: February 25, 2004, 11:22:50 AM »
I tried just about everything, it just wont move... I was told that there was a clip holding it in but no access to any clips at all.... I tried hitting it outwards but it didnt move.... I dunno... any other suggestions?
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
« Reply #3 on: February 25, 2004, 11:23:54 AM »
The couple I've taken apart were a bear to get out. I didn't care what happen to the shafts so I hit them out with a dead blow hammer(usually 2 shots). What's holding it in is a little round split ring on the end of the shaft.
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #4 on: February 25, 2004, 11:37:03 AM »
OK, guess I had the right idea, just not enough force.... Ill give it another shot... thanx for your help
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #5 on: February 26, 2004, 12:10:54 AM »
You can also get a pry-bar between the 3-bolt flange, and the case.  Just brutalize the snot out of it, and it'll come out.  Oh, yeah, rotate it while you're doing it.
Bob
Tahoe 24' Fish-N-Fun Tritoon
115 HP Mercury outboard
Offline Skunk
  • 147
  • Offroadnuts.com
    • Offroadnuts.com
« Reply #6 on: February 26, 2004, 03:20:01 AM »
we managed to get it out... now its just weld the carrier, and put the guts into the good housing.... I just wonder how the welded front end is gonna hold up... I know their not that strong.
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #7 on: February 26, 2004, 03:25:06 AM »
Hey, I've snapped the aluminum back lug on the 3rd member clean off, but I've never damaged the innards...
When I busted it, the front diff pivoted back, and up, and the U-Joint carved a hole in the bell housing!  ::)  I patched it with a Red Bull can, and some Silicone Rubber.
Bob
Offline Natebert
  • 1098
« Reply #8 on: February 26, 2004, 04:59:18 AM »
I patched it with a Red Bull can...
Those darn advertising people have brainwashed me to ask the question ..
Did it give your truck wings?
~Nate
Offline Bobzooki
  • 1754
  • Web Wheeler
« Reply #9 on: February 26, 2004, 05:38:27 AM »
~Nate
Absolutely!   ;D
Bob
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #10 on: February 27, 2004, 03:29:01 PM »
I gotta try that!  ::)
Mike
