Tire Comparasions
  • 11 Replies
  • 3782 Views
Offline NJONES
  • 4x4
Tire Comparasions
« on: February 23, 2004, 06:30:53 AM »
Has anyone ever ran the "Dunlop Radial Mud Rover"?
If so how does it work in a little bit of everything, mud, snow, sand and rocks. I ask this because i'm looking for a good all around tire plus good looks ;D, I have seen them for sale for 75 bucks each compared to goodyear and bfg's that are atleast 120 each.
Thanks,
Nathan
Offline ppltrak
  • 654
  • zukspeed staff
    • zukspeed.com
Re: Tire Comparasions
« Reply #1 on: February 23, 2004, 06:52:41 AM »
Check the search at the top of the page. Just type dunlop mud rovers.
        seeya ;D
              kevin
Offline ArkansasTracker
  • 85
« Reply #2 on: February 25, 2004, 02:44:12 PM »
I just put a set of the 30X9.5s on my Track Monday.  $505.xx out the door.  I haven't really tested them much yet, but will solve that issue this weekend locally and next weekend on some ORV mountain trails in Hot Springs, AR.  I'll keep you posted on the performance of the tires.
Also, I read an article at I believe it was 4X4review.com on the tires.  Decent all around ratings.
J
'96 Soft Top Geo Tracker, auto (leaking), coil spacers, 30X9.5 Mud Rovers
Offline 8yota9
  • 29
« Reply #3 on: April 08, 2010, 05:36:40 PM »
hey arekansastracker what size rims did you mount them on? got a set to lookin to mount them on my stock sammy rims.  there 15x7.5 rims. eney input tires are 30x9.5 will they bubble out to much ya think?
« Reply #4 on: April 09, 2010, 03:48:31 PM »
If they are really 15x7.5" rims they'll fit just fine. I didn't think stock Sammy rims were that wide, but I could be wrong as I don't own a Sammy. I've run 31x9.50 Swamper Tsl's on stock Trackick rims ( 15x5.5") and they worked well too.
« Reply #5 on: April 09, 2010, 06:44:03 PM »
Stock samurai wheels are only 5.5" wide.
Offline fordguy79
  • 494
  • 8
  • long beach Wa,
« Reply #6 on: April 10, 2010, 10:42:45 AM »
i have had dunlops before on a ford i had i hated them
Bobthebiker
« Reply #7 on: April 10, 2010, 10:57:38 AM »
this is more or less my motorcycle experience with dunlop in pretty much the same words.  not a fan of their products in general, even though the tread pattern looks pretty capable for what I might drive in down here.
Offline woof359
  • 111
« Reply #8 on: April 10, 2010, 12:29:25 PM »
stock Sam rims are 5.5 and if you run wider rims with 0 offset the rims are gonna be way close to the leafs in the back, you gonna need to push the rims outward just a little if you run wide tires.
CHUCK AND MICHELLE
Offline 8yota9
  • 29
« Reply #9 on: April 10, 2010, 01:30:35 PM »
yea they are 5.5 then. can i still run my 30x9.5 without isue? im gona try and mount them tonight hopefully. i could see maby a little leaf rubbing on the front but the back will be fine. by the way i put skys 4" spoa in her looks great!im goin from 205X7.0 to the 30's it shuld look awsome. picked the tires up for $100 yesterday one new the rest bout 65% gotta love craigslist.totally off topic but what size shocks can i put under her. lookin to go on the cheap side.
« Last Edit: April 10, 2010, 01:41:47 PM by 8yota9 »
« Reply #10 on: April 10, 2010, 05:45:11 PM »
I would just use the stock shock length, ran them for years without any issues.  You just won't have the mad flex.  :D  If you just flip your stock spring pads from one side of the axle to the other the stock position doesn't change.
We just put some 30x9.5 on 5.5 Tracker rims, worked fine.  Might be a little tight.
Offline 8yota9
  • 29
« Reply #11 on: April 11, 2010, 08:53:15 AM »
Yea i swaped them from side to side up front. rite is on the left and left is on the right is that what you mean?the shock mounting bolt on the pad is now on the inside. should i just switch them back? i read that i had to do that upfront with a spoa.
