Zuk tube clips
  • 30 Replies
  • 10632 Views
Offline rockrat
  • 196
  • Got Ringr
Re: Zuk tube clips
« Reply #15 on: February 08, 2004, 06:01:42 AM »
well make the trip out to chicago and we can set you up..
Offline Alaska101
  • The Original !! What started it all.
Siderkick tube doors!!!!!
« Reply #16 on: February 08, 2004, 10:05:26 AM »
Anyone have some photos I would like to see some on a 4door they would not work in winter but summer that would be great!!!!!!
1979 Lj81 Truck. Named REP-TAR! (Green thing from the rugrats)
Mod's include:
2001 GV frame w/ 2.0l dohc, and auto trany
Snorkel, 31x10.5 R15 tyres, Soon to be 35's
, also will have a dump box!!
Re: Zuk tube clips
« Reply #17 on: February 08, 2004, 09:30:42 PM »
Rock Rat,
I think the Tube Doors on a Kick would be sweeeettttt!!! If I lived closter I would definately get you to try it out. Fly down to Tennessee over a weekend and make a set ;D I have a 89 Kick to make them on and a 97 Tracker to double check everything ::)
Seriously, some tube doors with a easy remove/switch doors set up would be awesome.
Offline rockrat
  • 196
  • Got Ringr
Re: Zuk tube clips
« Reply #18 on: February 08, 2004, 11:18:29 PM »
I will start checking into it
Offline rockrat
  • 196
  • Got Ringr
Re: Zuk tube clips
« Reply #19 on: February 09, 2004, 12:19:07 AM »
Also I will be producing a cage for the Kicks seeing how there is only realy one out there.. I will give you some options.
Offline 1bigtracker
  • 3409
Re: Zuk tube clips
« Reply #20 on: February 09, 2004, 09:06:18 AM »
ya some cheap 4, even 8 point cage kits would be great.
Stu
Offline rockrat
  • 196
  • Got Ringr
Re: Zuk tube clips
« Reply #21 on: February 09, 2004, 10:27:20 AM »
Inexpensive maybee but never cheap
Offline 1bigtracker
  • 3409
Re: Zuk tube clips
« Reply #22 on: February 09, 2004, 10:31:14 AM »
i guess your right.  i used the wrong word.  cheap would be making it out of exhause tubing.  Inexpensive sounds alot better.
Stu
Offline ghd23
  • 406
  • 1990 Tracker softop, Detroit Mi.
Re: Zuk tube clips
« Reply #23 on: February 09, 2004, 11:29:32 AM »
They are in the works for samurai and as soon as  I get some one to donate there tracker for mock up they will be available also
Hey Brother; come and get one of these Trackers I got over here, Use it to build whatever you want, when your done I'll get it back from ya, take your time and get ir right
George;
If I Can't Weld It          It Can't Be Welded
Offline Tracker_Gt
  • 33
  • WOB WOB
Re: Zuk tube clips
« Reply #24 on: February 10, 2004, 04:07:55 AM »
as you all might know i myself am a welder
i was actually thinking about building myself a 4 pt roll bar i was just wondering what size pipe is standard for that kind of thing
also i should add you did a nice job
1990 Tracker, 4x4, 5 speed, 1.6, 4 door springs custom exhaust, custom paint, 31/10.5/15  - (sold)
1992 sidekick, 4x4, 5speed, 16valve, 4door, 3" home made body lift, 235/85/16's, (lots of cutting)
Offline rockrat
  • 196
  • Got Ringr
Re: Zuk tube clips
« Reply #25 on: February 10, 2004, 03:28:01 PM »
In the tite restraints of a zuk and kicks 1.5" .120 wall TUBING would be about all your going to get in.. Not saying you cant do larger but without modefying anything that size is best.
Offline Speedracer7c
  • 2210
Re: Zuk tube clips
« Reply #26 on: February 10, 2004, 05:19:43 PM »
I would love to see some plans of a 4 pt. cage. That would be awesome If someone could draw some up.
Offline 1bigtracker
  • 3409
Re: Zuk tube clips
« Reply #27 on: February 11, 2004, 07:04:48 AM »
Ya we are going to need them if we are going to go to gon zookin.
Stu
Offline Tracker_Gt
  • 33
  • WOB WOB
Re: Zuk tube clips
« Reply #28 on: February 11, 2004, 08:02:24 PM »
when i build my roll bar iam gonna buy the pipe from my old welding shop then take it to an exhaust shop for mandrel bending then take it all back to the welding shop and borrow a mig welder for 10 minutes
heres my second question my tracker is that blackish purpleish colour with red stripe and a white soft top
should i make the roll bar match the interior (grey)
the body (black)
or the striping (red)
Offline rockrat
  • 196
  • Got Ringr
Re: Zuk tube clips
« Reply #29 on: February 12, 2004, 11:08:29 AM »
PIPE IS FOR PLUMBING
