Heater
  • 1992 Views
Offline van7559
  • 145
  • I'll Leave Tracks All Over Your As$
Heater
« on: February 11, 2004, 01:07:25 PM »
`I 'Ve got a 95' lsi and the heater has four settings, but mine only works on the last two what could it be, b/c if you leave it on the third setting all the time it gets too damn hot, also my passenger side vent next to the pass. window does not blow air , any help would be appriciated.
95' Kick with a 3 in. body lift and plenty more to come!
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
Re: Heater
« Reply #1 on: February 11, 2004, 02:01:19 PM »
I had the same problem with my '96 and I did what the dealer said couldn't be done. I removed the switch and cleaned the contacts then put it back together with a wire tie around the switch housing to keep it tight. If you chose to do this, be careful or you'll lose the detent ball and spring when you take it apart.
Re: Heater
« Reply #2 on: February 11, 2004, 03:31:49 PM »
My solder connections have come loose twice
but it's been 6 years since I've had to fix it.
Remove switch, re solder the wires onto the
contacts on the body of the switch and it should
work fine.
Offline JokerWhiskey
  • 157
  • holy poop! a fuzzy bunny!
Re: Heater
« Reply #3 on: February 12, 2004, 04:46:03 AM »
as for the vent not blowing air, maybe a hose disco'd?
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: Heater
« Reply #4 on: February 14, 2004, 10:50:22 PM »
OR MAYBE SOME FIELD MICE TOOK UP RESIDENCE IN THERE  ???
