s.a.s pics?
  • 26 Replies
  • 7203 Views
0 Members and 14 Guests are viewing this topic.
zukicidal
Re: s.a.s pics?
« Reply #15 on: February 10, 2004, 09:38:57 PM »
Is his rear axle centered diff? Where did his Dana's came from? I'm looking at getting a set of Jeep Quadratrac axles from a CJ7; D30/AMC20 locally for $50. I've heard 5.38's are steepest available for the combo.
I got the info from Eric:
"they're 4.27 r&ps... the rear is
centered, axles are D30 and D44 from '73 CJ5."
Offline jagular7
  • 1026
  • Jagular7
Re: s.a.s pics?
« Reply #16 on: February 11, 2004, 05:32:54 AM »
That's the stock ratio for Jeep with the v8/3-sp combo back then. Friend had one 10 yrs ago.
So he running 1.6l, 5-sp or auto (?), Sami 6:1 t-case, running 4.27's on what looks like 35x15.50 Swampers?
Is it a daily driver? What is his rpm at highway speeds?
On his front suspension, he has the centered tri-link from the pics on ZOA's website. Does he have a track arm, couldn't see one? I wonder how much it wonders on the road at speed. The track arm is what locates the axle side to side under the truck. With the pitman arm pushing/pulling on the drag link to the passenger knuckle, there has to be something like the track arm to resist that push/pull effect.
Lenexa, KS
Offline Fredo
  • 416
  • Heavy music and Suzuki 4x4!
Re: s.a.s pics?
« Reply #17 on: February 11, 2004, 12:38:31 PM »
I speak to this guy today, 37"x13" bogger!!!!!!!!
Hum interesting.
Fredo
Proud member of the C.A.B.L (coalition against body-lifting) 2002 GV
zukicidal
Re: s.a.s pics?
« Reply #18 on: February 11, 2004, 12:41:16 PM »
What you're calling a track bar, we call a panhard bar. Tamayto, tamahto. LOL  That's the third link on the front. Stock 1.6 eight valve with a five speed.  You got the tire size right.  He says it drives fine, but he had those tires on his old Samurai too so he's probably used to them. Plus now he has power steering.  :)  One thing you don't see is the rear anti-sway bar.  Without it, the thing would tip over on flat ground!
Offline ksa421
  • 382
Re: s.a.s pics?
« Reply #19 on: February 11, 2004, 02:07:16 PM »
Hey Fredo do happen to have any info or pics of that guys suspension setup and/ or know what axels he is running.
 I am planning on doing a SAS and trying to decid on either a coil or leaf setup. What are your guys thoughs? Thanks
Jacob
'90 Kick, Calmini 6" lift, 32x10.50 Pro Comps, Calmini bumper, 8000lb winch, 1.6l VW TD;
Offline Kreg
  • 795
  • Yo Ho, Yo Ho, a four wheelers life for me.
    • Island 4x4
Re: s.a.s pics?
« Reply #20 on: February 11, 2004, 02:35:49 PM »
Scout 2, or CJ5 narrow track axels are probabaly your best bet because they match a sidekick in width very closely.
As far as suspension goes, I dont have any good details. But If I were to do it, I'd go for coil all around.
Offline idaholwb
  • 772
Re: s.a.s pics?
« Reply #21 on: February 12, 2004, 06:55:12 AM »
 Heather will probably be on the SAS this weekend. Not 100% sure about the height. We're shooting for about 4" taller than where she is now.
To say the least, she'll be done by Moab!
It kinda sucks, though. The front end I built for her truck, turned out waaay better than the one for mine! To say the least, her front is literally "BULLET PROOF!" It has 1/4" armor welded onto the front and bottom of the diff housing.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline track_this
  • 332
  • Live for something or die for nothing
Re: s.a.s pics?
« Reply #22 on: February 12, 2004, 04:50:47 PM »
check this out  :o
1994 geo tracker 1.6L 16v 4x4 2dr soft top 5.12 gears.MODS:
calmini 3 inch sus. lift
rear lockright
31" kumho m/t's
RRO 2" body lift custom snorkel front & rear trail tough bumpers-Tabor 9k winch(warn) 100amp alt. grand vitara steel 3rd member
Offline Kreg
  • 795
    • Island 4x4
Re: s.a.s pics?
« Reply #23 on: February 12, 2004, 05:17:58 PM »
Wow thats dope!
Hopefully mine will be able to do that in a few years! ;D
Offline jagular7
  • 1026
  • Jagular7
Re: s.a.s pics?
« Reply #24 on: February 13, 2004, 04:14:38 AM »
check this out  :o
Take note: if the spare is laying flat in the back, how would he go about getting it out, yet alone getting the flat one back in?
Look at those steps on the sides. He probably steps on the rear tire, then steps on the step platform. To get out, he probably bungee cords.....
Lenexa, KS
Offline 1bigtracker
  • 3409
Re: s.a.s pics?
« Reply #25 on: February 13, 2004, 12:13:58 PM »
does that thing have f**king rockwells under it?
Stu
« Last Edit: February 13, 2004, 12:14:20 PM by 1bigtracker »
Offline Fredo
  • 416
Re: s.a.s pics?
« Reply #26 on: February 14, 2004, 09:49:22 AM »
Hey! Ksa421 check this. Ok it's in french but if you don't understand a thing i will translate it for you.
Toyota axles front/rear with TJ coils on 4 corners.
http://www.quebec4x4.com/histoire2003/sidekick/sidekick.html
Fredo
« Last Edit: February 14, 2004, 10:03:41 AM by Fredo »
