Are 2wd and 4wd Outters the same?
  • 2658 Views
« on: February 11, 2004, 09:25:22 PM »
OK I do know the name, I'm thinking Hub (not Lockout). The outter Hub/Spindle ??? the steel peice that holds your wheel bearings, brakes, attaches to your strut etc...  Are they the same on a 2wd and 4wd tracker??? I had a parts guy say yes, and then another said no :-/
Thanks,
Re: Are 2wd and 4wd Outters the same?
« Reply #1 on: February 12, 2004, 12:57:19 AM »
They both were right, yes it is the same and
no there is a plug in the back of the spindle
where the axle stub goes thru, BUT you could
pop that plug out and then use the spindle for
your truck.   ;D
Offline Mac
  • 407
  • Toys, Toys, Toys
    • 1985 Suzuki Samurai
« Reply #2 on: February 12, 2004, 01:23:45 AM »
I am not sure on the Trakkick, but on the Sami the were not interchangable.
Mac
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #3 on: February 12, 2004, 01:25:15 AM »
Check to make sure that the bushings for the axil is in the spindles if you knock the plug out.
32 MTR's Warn 8000i
« Reply #4 on: February 12, 2004, 01:28:05 AM »
It's not, I forgot about those  :P
but you could recycle the old ones
if you got a bent spindle  :)
Offline lil_Truck
  • 1148
  • Eric Gardner
« Reply #5 on: February 12, 2004, 01:42:34 AM »
Probally could install new bushing, but then mabe not.  It would depend if there machined or not.
32 MTR's Warn 8000i
« Reply #6 on: February 12, 2004, 01:54:24 AM »
My problem is that I did not get all of the axle peices out when I broke my outter stub shaft. A peice of the axle wedged between the lockout and the retaining washer and filed it and the screws down flat. I'm afraid that I will find more damage if/when I drill tou the screws and remove the bearings. So I was just going to pull the ones off of my 2wd parts tracker(spindel hubs brakes etc...) Con I get the axle bushings from an parts store if they are dammaged, or will I need to order them Hawk.
Offline Mikerpm4x4
  • 2875
  • Redline... all the time!
    • www.rpm4x4.com
« Reply #7 on: February 12, 2004, 02:08:32 AM »
Im pretty sure they will fit. You will need to swap the bushing and seal though.
Mike
