2in lift
  • 34 Replies
  • 8761 Views
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: 2in lift
« Reply #15 on: January 28, 2004, 09:45:23 AM »
No, they are made for different ride hights.
32 MTR's Warn 8000i
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: 2in lift
« Reply #16 on: January 28, 2004, 09:45:49 AM »
I didn't see any front springs in that kit.
Am I wrong  ???
You can see the difference.
32 MTR's Warn 8000i
Offline 1bigtracker
  • 3409
Re: 2in lift
« Reply #17 on: January 28, 2004, 10:48:02 AM »
i dunno, they look almost the same.  a little more braceing on the 3in.
Stu
Offline idaholwb
  • 772
Re: 2in lift
« Reply #18 on: January 28, 2004, 11:08:23 AM »
 I've installed both lifts on kick's before. The spring pocket is a slightly different position between the two arms. I'm not sure, but I think the 3" arms are just about the same spring pocket as the stock arms, just a heavier design with a different ball joint angle (but I could be wrong about that). If you have Heather post some pics about her 95 4dr suspension, you'll see that she uses the Calmini 2" with different front springs and BDS lift TJ springs with a modified 3" body lift and with a little creative sheetmetal work, she clears 33s with no problem! Can't wait till she goes SAS!!! ;D
97 Sport
265/70-16s
2" lift
2.0 swap
Offline 1bigtracker
  • 3409
Re: 2in lift
« Reply #19 on: January 28, 2004, 11:22:47 AM »
i fit 34s with a 3 in body lift  :P   lol
Stu
Offline van7559
  • 145
  • I'll Leave Tracks All Over Your As$
Re: 2in lift
« Reply #20 on: January 28, 2004, 01:14:11 PM »
Heather, what is your web site, or please list the mods you have done to your 2in lift? Part numbers if at all possible.
95' Kick with a 3 in. body lift and plenty more to come!
Offline DoRoN
  • 1990 Kick
    • Doron 4x4
Re: 2in lift
« Reply #21 on: January 28, 2004, 06:07:47 PM »
This is Heather's web site:
http://www.whitepineclub.com/members/kd7hcg/sidekick.html
I've been following their work and their websites for almost 2 years, and I must say I enjoy it every time I click to get in  :)  8)
http://www.omghi2.us/april05/DoRoN_sig4x4.JPG[/IMG]Free your mind, and the rest will follow...
Offline Speedracer7c
  • 2210
Re: 2in lift
« Reply #22 on: January 29, 2004, 12:19:16 AM »
She has Lifted BDS TJ springs in the back. and some just longer than stock springs in the front.
Offline hcgalvin
  • 1695
    • Granite Path
Re: 2in lift
« Reply #23 on: January 29, 2004, 02:42:21 AM »
Thanks! I appreciate the compliment.. I try to keep that thing updated..
Heather Galvin
Offline hcgalvin
  • 1695
    • Granite Path
Re: 2in lift
« Reply #24 on: January 29, 2004, 02:48:39 AM »
Here's what I am running with my Calmini 2 inch. However, we like to custom make a lot of our stuff, it's a lot cheaper that way, especially if you have buddies with welders, BFHs, Cutting Tools, and torches. ;)
I am running Rancho 5115 shocks in the back, they work well and allow for about 2 inches more droop than the Calmini ones. I also ran OEM (FRONT!) Jeep TJ springs in the back, but upgraded to the 2" Lifted BDS Front TJ Springs. I have a heavy butt on my truck, if you haven't seen the bumper. *grin*
I also ran Daystar Jeep TJ Spring Spacers 1 3/4" in the back for a long time, but took them out with the BDS springs.
We have a custom extended wheelbase:
http://www.whitepineclub.com/members/kd7hcg/pictures/wheelbaseext/index.htm
That was to fit the 33's... The rears in 4 Doors are different than that of 2 doors, so some of you might not have this problem.
And we are running longer I don't know what they are coil springs in the front.
Heather
Heather Galvin
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: 2in lift
« Reply #25 on: January 29, 2004, 11:32:15 AM »
It's the result of the large caverness space between the lugs. Stick your head out the window and listen to them purr as you pick up speed. Pretty coolllll....People can hear you coming.
;D ;D ;D ;D
  • 2274
Re: 2in lift
« Reply #26 on: January 29, 2004, 11:34:36 AM »
I think that they say that 32x9.50 fit with no rub if you do minor triming ???
Sorry, I meant to quote NY :P
I WENT BACK AND LOOKED BECAUSE I WAS WONDERING IF I MISSED THAT BUT ITS NOT THERE...I'M GONNA PROBABLY SEE IF MY NEIGHBOR WILL TRIM THE REAR OF THE FENDER & BUMPER.....MATTY D.  8)
  • 2210
Re: 2in lift
« Reply #27 on: January 29, 2004, 01:43:50 PM »
I'm hoping that with 2 inch suspension and 3 inch body i can run 31X9.50's with the stock bumpers without having to do much trimming.
Offline 1bigtracker
  • 3409
Re: 2in lift
« Reply #28 on: January 30, 2004, 07:25:59 AM »
;D  if i could get one with devil ears i would.
Stu
Offline Natebert
  • 1098
Re: 2in lift
« Reply #29 on: January 31, 2004, 04:27:56 PM »
I'd say this is probably very do-able, but keep the angle grinder/BFH handy... :D
~Nate
