Electric Radiator Fans
  • 14 Replies
  • 5795 Views
Offline Speedracer7c
  • 2210
« on: February 03, 2004, 12:52:53 PM »
I was wondering if anyone has any suggestions for ditching the stock fan in favor of an electric fan. Cause I noticed when wheelin hard my temp seems to like to creep up. I was debating on wether on not to goto a lower temp thermostat but I decided against that. Any suggestions or Ideas are appreciated.
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Electric Radiator Fans
« Reply #1 on: February 03, 2004, 01:00:02 PM »
I have AC on mine and it comes with an additional electric fan on the front of the rad.
I've thought of putting a switch on it so that I can turnit on and off myself for such suituations.
You might think of adding a fan that way.  I have a friend that had just an electric fan on just a switch and kept forgeting to turn it on and had all kind of problems with it.
Also, there's no electric fan that can match your mechanical one.  You can get close but can't match it.
« Last Edit: February 03, 2004, 01:00:49 PM by lil_Truck »
96 Tracker
32 MTR's Warn 8000i
Offline TN_Tracker
  • 1113
    • TN Tracker's Suzuki Space
« Reply #2 on: February 03, 2004, 01:03:37 PM »
I'm thinking about trying this one:
http://www.jacksongalleries.com/alex/jeep/taurusfan/
  • 2210
« Reply #3 on: February 03, 2004, 01:32:05 PM »
Maybe I will do an electic fan as well as the mechanical. I just want it to run as normal as possible when running it hard.
Offline Alaska101
  • The Original !! What started it all.
« Reply #4 on: February 03, 2004, 01:44:48 PM »
I run a elec. fan on my 8v and even running hard like towing it will not heat up. Forget about running both elec. and manual fans just go elec. I run a 16in fan and that is the biggist one that would fit.
1979 Lj81 Truck. Named REP-TAR! (Green thing from the rugrats)
Mod's include:
2001 GV frame w/ 2.0l dohc, and auto trany
Snorkel, 31x10.5 R15 tyres, Soon to be 35's
, also will have a dump box!!
« Reply #5 on: February 03, 2004, 03:03:11 PM »
I had an electric 16" fan, had to change
back to the belt driven one, not enough
air flow to keep the intercooler and the
radiator cooled off. I don't suppose the
extra heat from the turbo had anything
to do with it  ::)
Offline trialspro
  • 149
  • 1984 suzuki sj410 lwb, spoa... rusty
« Reply #6 on: February 03, 2004, 03:38:29 PM »
sorry to jump a little off topic, but whats wrong with just changing your thermostat? not radically, just like a step down, if they go like that.  it might run a LITTLE cool in the winter, but i dont think it would be too drastic of a change
Andrew
  • 2210
« Reply #7 on: February 03, 2004, 03:51:50 PM »
I had asked that in my question, I dont' see whats wrong with it either, But who knows. Maybe I will try that before resorting to an electric fan. What is the stock thermostat at? 180? Thanks ,Andrew
Andrew
Offline Somer
  • 143
  • Hey, is it suppose to do that!!
    • D2
« Reply #8 on: February 03, 2004, 10:34:47 PM »
Andrew
Here in Japan, in the summer time a lot of people just run their Jimnys with out a thermostat at all, but I can't say whether or not it is the best thing to do.
  • 2210
« Reply #9 on: February 03, 2004, 11:09:07 PM »
It is not good to run without a thermostat at all, cause the coolant flows too fast and doesn't properly heat the head up, which can result in a cracked head.
Offline Ronzuki
  • 261
  • What's a Samurai?
« Reply #10 on: February 04, 2004, 01:49:06 AM »
Also, if you like the mud and underwater excursions there might be some problems associated w/ electric fans.
'91, RRO Bolt-On SPO, 32" BFG Muds, 2" BS U.S. Wheels, Breeeze CO, Neon Seats, 5.8:1 T-Case, TT Mighty Kong Bucket, 1.5" RUF, 1.5" Rears, DT Shocks, RRO Sliders ,Rear DetroitEZ, OBA,Celica PS
RCrocs Team 509
« Reply #11 on: February 04, 2004, 04:43:07 AM »
The only temps of thermostats I have
found are stock 180* and 160*, I really
wanted a 170* but never could find one.
Now it may be available if special ordered
but I have never tried.
BTW I run a 160* and heater is just warm
in the cold (ya right So. Cal. Cold) winter
which is about 30* here and 15* in the
Mountains   :)
Offline 1bigtracker
  • 3409
« Reply #12 on: February 04, 2004, 06:48:36 AM »
ya winter around here its almose 25 below.  a tid bit colder that so cal.
Stu
Offline wolf66
  • 193
« Reply #13 on: February 04, 2004, 08:53:47 AM »
Actually i run a electric fan because i go in deep water, i have a switch in the cabin so i can turn it off.
Belt driven fans have been known to crack/break off blades upon hitting rising water while spinning.
+ your engine should spin up a little faster without the extra drag of the fan
« Last Edit: February 04, 2004, 09:13:49 AM by wolf66 »
'96 Suzuki X90-4" lift-snorkle-30x9.5's on 8x15 wheels-5.12 gears-winch-added rear seat-DT header-PioneerMP3-CB-GPS-roof rack-rear mounted full size spare
95XL7
« Reply #14 on: February 04, 2004, 09:11:11 AM »
Mine has dual 12" fans with a adjustable thermostat. Seems to be plenty to keep the V-6 cool.
