Fuel Pump Needed?
  • 2798 Views
Offline Captain_Jack
  • 80
Fuel Pump Needed?
« on: February 01, 2004, 02:11:09 PM »
When doing the 16V conversion - How much psi fuel pump is needed.  Do you have a favorite pump to mount in the frame rail by the gas tank?
Also, can we use the stock catalitic converter or do we need the Tracker Cat?
Captain Jack
Offline Zuki One
  • 441
    • ZUKI - PICS
Re: Fuel Pump Needed?
« Reply #1 on: February 01, 2004, 04:57:35 PM »
I beleive you need a pump that does 40PSI,i found on a another site
a napa part#2p74028 $70 bones you said you talk to brent for your kit just ask him to put a pump with it its the same price and it comes to your front door ;D
« Last Edit: February 01, 2004, 05:01:47 PM by Bug_D »
"Sooo What shop built your rig?"hahahahhahahah    www.cardomain.com/memberpage/607888/1
  • 80
« Reply #2 on: February 02, 2004, 02:15:25 AM »
I too saw the post about the NAPA pump # 2P74028.  I checked out the NAPA website.  it said this pump was a 7 PSI.  I'll have to contact the local store to make sure.
I already have the adapter.  No pump came with it.
Captain Jack
  • 80
« Reply #3 on: February 02, 2004, 10:26:04 AM »
The wrecking yard where we got our engine threw in a pump from a 5.0 fuel inj. Ford pickup.  Hope it's ok.
Captain Jack
Offline idaholwb
  • 772
« Reply #4 on: February 02, 2004, 03:40:09 PM »
 The pump you need is from a 86-89 Ford Ranger with a 2.9 v6, it's the external pump. They also had an in-tank pump, don't try that one, it's a submersible pump that will be too hard to make work. The external, if you get it from a junkyard, try to get about 6" of fuel line frm either side of the pump because of fittings.
Another one you could try would be a 88-92 5.0 or 5.8 liter v8 F150, the external pump.
These 2 pumps are probably the best and easily adaptable pumps to use.
Hope this helps.
97 Sport
265/70-16s
2" lift
2.0 swap
