Towing
  • 14 Replies
  • 3917 Views
Offline zukiboy
  • 42
  • Wheel Forever !!!
Towing
« on: January 31, 2004, 05:10:42 PM »
What is the correct way to flat tow my 88 Zuki. With transfer case in neutral ,trans. in gear and hubs locked ??? I'm new to Suzuki's. Thanks
88 sami
3"lift 30's
No matter where you are there you'll be
Re: Towing
« Reply #1 on: January 31, 2004, 11:04:44 PM »
T-case in neutral, Trans in neutral, Hubs unlocked
Offline biker
  • 730
  • It's a sickness I tell ya
Re: Towing
« Reply #2 on: February 01, 2004, 02:13:14 AM »
Actually, I believe that the main transmission must be left in gear to prevent it from spinning with out lubrication. The transfer must be in nuetral and the hubs unlocked.
94 Kick with bigger tires
99 Vitara 2wd
10 Gr Vitara
Offline zooky
  • 135
Re: Towing
« Reply #3 on: February 01, 2004, 02:34:53 AM »
T-case neutral
transmission in 2ed gear
turn key to on then to off BUT DO NOT REMOVE IT, this leaves the steering wheel unlocked and accesories off.
Offline TinTopper
  • 73
  • 1987.
    • dayid.org
Re: Towing
« Reply #4 on: February 01, 2004, 02:40:50 AM »
T-case neutral
This is the best suggestion thus far --- you forgot that if you're doing the 2nd gear thing - DO NOT EXHEED 45MPH!
Whoever said to put it all in neutral... nooooooo
If you're going anywhere and want to go more than 45MPH while towing it -- taking the 5minutes to detach your driveshafts and do it right!
'87 TinTop
'04 F-150
Offline NY_SIDEKICKER
  • 2274
  • YOU WANNA RACE THE ZUKE !
    • OBSESSIVE BEHAVIOR !
Re: Towing
« Reply #5 on: February 01, 2004, 03:57:29 AM »
THIS BRINGS TO MIND SOMETHING I READ HERE OR IN THE WATER COOLER ABOUT THE GUY HAULING HIS SAMMY FLYING DOWN THE HIGHWAY WHEN THE PERSON PULLED HIM OVER TO LET HIM KNOW HIS SAMMY WAS ON FIRE ....POST IT AGAIN I COULDN'T FIND IT...I SAY TAKE THE 5 MINUTES TO PULL THE SHAFT AFTER READING THAT....... ;) IF ITS NOT REPOSTED I'LL FILL IN THE BLANKS BUT TO READ THE ORIGINAL POST WOULD BE BEST......MATTY D.  8)
Offline MB
  • 223
Re: Towing
« Reply #6 on: February 01, 2004, 05:24:35 AM »
I think this is the story
http://monkeycage.island4x4.com/showthread.php?s=&threadid=4966
Re: Towing
« Reply #7 on: February 01, 2004, 05:30:08 AM »
Tranny can't turn on a Man trans even in Neutral,
clutch is preventing it, also man Trans is lubbed
through the gears spinning and picking up oil.
However if the T-case or the Trans got bumped into
gear and the Trans was in say 2nd, you might have
a meltdown of your own  ;)
Just somthing to think about
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Towing
« Reply #8 on: February 01, 2004, 07:38:47 AM »
I've got many thousand miles flat towing my Tracker.  It's a stick.
I've always put both the trans and t-case in neutral.  Never had a problem.
Like wildgoody said:  "Trans is lubbed through the gears spinning".
If I plan on wheeling it hard I'll try to find a trailer incase I brake something and can't tow it back.  Would suck to be in another state and have that happen.
Hoping to buy one this spring.  ;D
96 Tracker
32 MTR's Warn 8000i
  • 2274
Re: Towing
« Reply #9 on: February 01, 2004, 07:46:11 AM »
YUP THAT WAS IT........DID THEY EVER COME UP WITH ANY PICTURES  ???  MATTY D.  8)
Offline MB
  • 223
Re: Towing
« Reply #10 on: February 01, 2004, 10:52:10 AM »
haven't seen any yet :-/
Offline MB
  • 223
Re: Towing
« Reply #11 on: February 01, 2004, 11:01:21 AM »
While I'm thinking about it I thought I'd share this tragic story.
A while back I posted the same question on towing a 90 track. Any how some might remember the comment I made about my brother having problems towing his track on a tow dollie and being bullheaded (gonna do it my way ...Well this friday the phone rings it's my bro. "Can you bring your truck and a two strap and get me?" Transmission dropped all but the 4th gear and the transfer is also gone. Soooo God help me I took my heep pickup and towed him home. (head hangs in shame)..So now his toy sits in the garage awating new trans/transfer. Moral of the story... when in doubt, PULL that shaft!
Offline Brandon
Re: Towing
« Reply #12 on: February 01, 2004, 01:13:21 PM »
not the easiest way but the safest is probably to drop the rear shaft and leave hubs un-locked,I work for a tow company part time and the only way we can tow a rear drive or 4wd truck is to drop the rear shaft
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Towing
« Reply #13 on: February 02, 2004, 12:51:37 AM »
Now if only we could come up with lockouts for the rear?  ::)
Hows that coming wildgoody ???
96 Tracker
32 MTR's Warn 8000i
Re: Towing
« Reply #14 on: February 02, 2004, 02:24:12 AM »
Waiting for some spindles from the front
of a Track/Kick, after that it will be on it's
way. I've been looking at some Nissan
Maxima rear brakes, nice big disks with the
E-brake in the caliper, I think they are more
available than Saturn Rear Disks, that and
all the Saturns I found were Drums or stripped
of their rear disk hardware  >:(
Also the Maxima rears are Tokico which is
Zuki native parts, I don't think I'll have any
rejection issues with native parts  ;)
