Rhino Lined
  • 27 Replies
  • 6921 Views
Offline r0ckstarr79
  • 400
  • Chevy + Zuk
Rhino Lined
« on: December 19, 2003, 10:59:12 PM »
Anybody Rhino-lined (spray-in bedliner or whatever its called), the inside of there zuki? I gutted my samurai out and cleaned it all up on the inside. (Had about a 1/2 inch of sand and dirt under the carpet from going to the beach so much). Im going to have it sprayed in on the floors and somewhat up the sides of the interior....... Also, how much did it cost?
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Rhino Lined
« Reply #1 on: December 19, 2003, 11:21:02 PM »
I think we just talked about something like this?
Anyway, it sounded like the rollon stuff is tough but a little ruff.  It's realy takes some scrubing to get the mud out of it.
I'm thinking about using the spray can kind.  It's not so ruff and it still tough.  My brother-in-law did this on his Jeep and was happy with the results.  It only took 2-3 cans.  He didn't go realy thick.
He said the key was to make sure the paint was scruffed up enoff.
32 MTR's Warn 8000i
Offline ghd23
  • 406
  • 1990 Tracker softop, Detroit Mi.
Re: Rhino Lined
« Reply #2 on: December 20, 2003, 01:20:26 AM »
 :D :D :D   Good stuff, just follow the instructions and you will get a good job.  Also works real well on lower body panels, the bottom of your doors, door openings so on and so on. Anywhere you may aquire rust. Also easy to paint over.    George; :D :D :D
If I Can't Weld It          It Can't Be Welded
Offline 1bigtracker
  • 3409
Re: Rhino Lined
« Reply #3 on: December 20, 2003, 01:26:39 AM »
I was going to get a spay on job done to the inside of mine but it cost some crazy money.  lata stu
Offline Z3bra
  • 273
Re: Rhino Lined
« Reply #4 on: December 20, 2003, 01:38:14 AM »
What about this:
http://www.por15.com/product.asp?productid=249
I have heard nothing but good stuff about all the POR-15 stuff.  The only thing even remotely close to bad that I have heard is that the rust preventative standard POR-15 is not good to paint over since paint doesn't adhere to it worth beans. Then again, they do make a primer to cover it for painting so I guess that doesn't really qualify as a bad thing
Offline van7559
  • 145
  • I'll Leave Tracks All Over Your As$
Re: Rhino Lined
« Reply #5 on: December 20, 2003, 06:28:36 AM »
I got the interior of my track linexd, at a dealer for 420 and yes it is a waste of money. I didn't get it sprayed on the driver an passenger floor boards, b/c that is why the make floor mats. It is a bitc% to clean after mudding, and it always looks dusty, but if you ride with the top off alot like me it sure beats the hell out of cleaning carpet. I would rather of spent my money on a front bumper.
95' Kick with a 3 in. body lift and plenty more to come!
Offline bandit86
  • 1641
  • elv8rguy
Re: Rhino Lined
« Reply #6 on: December 20, 2003, 12:44:52 PM »
the whole point of having rhino coat, (I used hippo liner for $50) is to protect your truck from scratches, that would rub through the paint and start the rusting process.  if you're worried how clean your truck is under tha carpet, dont go offroading.  I put it in so that if I have a puddle under my carpet I dont know about, it wont rust out my floor boards.
Offline ksa421
  • 382
Re: Rhino Lined
« Reply #7 on: December 20, 2003, 06:37:58 PM »
I just happened across this I think this is what you are wanting to do right. I am planning on putting some kinda roll in bed liner in the summer, my carpet is getting a little funky. What is a good brand to look for and what does it cost to do your self on average?
http://off-road.com/suzuki/tech/durabak.htm
Jacob
'90 Kick, Calmini 6" lift, 32x10.50 Pro Comps, Calmini bumper, 8000lb winch, 1.6l VW TD;
Offline lil_Truck
  • 1148
  • Eric Gardner
Re: Rhino Lined
« Reply #8 on: December 22, 2003, 07:36:53 AM »
They're making a colored spray-on liners now.  Get a cheep gun, go down to you paint store and see what you can get.
A friend on mine was telling of a guy that took color bed liner.  Painted his truck, and then clear coated it.  I guess it didn't look too bad.
32 MTR's Warn 8000i
Offline 87BlackSami
  • 191
  • http://www.quic kvwbug.4wdriver .com/
    • http://www.quickvwbug.4wdriver
Re: Rhino Lined
« Reply #9 on: December 22, 2003, 09:39:16 AM »
Here is what I did.
 Stripped out the lower part of the interior including seats, carpets, and any other junk on the floor from the pedals to the tail gate.
 Then I vacuumed allthe dirt and followed up with a good scrubbing with laquer thinner.
 After that dried, I sanded with 80-100 grit sandpaper everywhere you are going to put the product.
 Next I wiped down again with thinner to remove any sandings and oils.
 Using masking tape I masked where the product will stop on the fire wall, on the sides by the seat belts, all the bolt holes for the seats and along the top by the tailgate.
 I went with Herculiner because I  like the granual rubber texture. If you want a smooth texture I recommend DupliColor. Herculiner is available in black, red and I think blue. DupliColor makes a tintable liner so you can match any color you want.
 I applied a light coat first then laid out the rest of the gallon after 15 minutes. I put thicker material on the floor boards and bed. Two coats on the sides were plenty for the effect and protection. When it starts drying you can really build it up to a desired thickness.
 Once all the product was applied and set up for an hour from the time I started, I peeled away the tape to reveal a crisp clean line.
 Allow this to really dry before use, probably 2 days or so. then install your seats and whatever else.
 I don't think it's to bad for cleanup just use a hose and some Castrol SuperClean.
 By the way if anyone has rusted drain holes I have a tool I made for stamping new dimples for the drain plugs. I can make any size patch panel you need for your floor and you can weld it in.(E-mail me for details or if interested)
I hope my little instruction helps out. ;D
locked,5.8:1 Tcase, 5.12's, 35x12.5Xterrain's, 4" BDS L/O, Ford towers, 5-8" shackles w/reverse, tracbar, Yota P/S, diffs capped, skidplates, onboard air, fabbed bumpers & shafts, Herculined, airhorns
Offline Cowtracker
  • 39
Re: Rhino Lined
« Reply #10 on: December 23, 2003, 07:02:07 AM »
 Since my rig's primary duty is a daily driver,  I wanna know if this bedlinner stuff will deaden road noise to near the level of carpeting?( with a thick application like 4-6mm)
Experience....any body wanna coment?
« Last Edit: December 23, 2003, 07:04:19 AM by Cowtracker »
Guitars,zukes and hilbilly music!
Offline Mike71
  • 1449
Re: Rhino Lined
« Reply #11 on: December 23, 2003, 07:58:42 AM »
if u make it thick enough sure it will deaded road noise
i have heard a couple people say they were suprised that it wassent as noise as they had expected or as noisy as it was b4 the liner
Offline 87BlackSami
  • 191
Re: Rhino Lined
« Reply #12 on: December 23, 2003, 01:23:50 PM »
It deffinitly took out the rattles but there isn't much that would quiet down the 2.5'' flowmaster. ;D
Re: Rhino Lined
« Reply #13 on: December 23, 2003, 05:13:01 PM »
My trucklet is an '89 JLX, came with body color painted
side mirrors and license plate light/cover, now after
14 years of being an outside trucklet, the plastic was
loosing the paint, so I got some spray-on bed liner
and had at it, the nice thing is the thick coverage hides
the rough missing paint spots, and now with more cars
coming with black painted on these parts, it looks real
good again, adds a Butch look to the outside, that and
the hood scoop for the cold air ram for the turbo, adds
a mean look to the hood.
;D
Offline Maiden Hell
  • 1650
  • MAIDEN HELL!
    • My Space
Re: Rhino Lined
« Reply #14 on: January 31, 2004, 04:29:10 AM »
I found some dealers in my neck of the woods who I am going to get some prices from to do my entire interior... I was shocked to find my driver's side floor board completely soaked from snow and slush last night.  I brought in my mats and carpets to dry in the boiler room and went out this morning to go and soak up the rest of the water with some old rags while I left my engine idling with the heat on and the fan full blast re-circulated air to the floor to help dry up quicker.  I even stuffed the passenger side vent with some gloves to force most or the air onto the drivers side.  Worked like a charm, all nice and dry again.
