Problem with X-90
  • 3171 Views
Offline bbagwell
  • 278
Problem with X-90
« on: January 11, 2004, 03:38:14 AM »
I have a clutch problem with my 1996 Suzuki X-90.  I replaced the clutch cable, clutch disk, pressure plate, and bearing.  All was good for about 50 miles.  Then it started to slip so bad I can barely even drive it at all.  After installing the new clutch I had to tighten the cable a lot more than I thought I should have too with a new clutch and new cable.  Does anyone have any ideas what could be causing the problem?   ??? Any help would be much appreciated.
2002 Suzuki Grand Vitara
1983 Toyota PU
Offline bandit86
  • 1641
  • elv8rguy
Re: Problem with X-90
« Reply #1 on: January 11, 2004, 07:31:48 AM »
cable too tight?  Engine rear main seal leaking?  How much free play do you have on your pedal? the arm on the bellhousing?
Offline bbagwell
  • 278
« Reply #2 on: January 11, 2004, 08:48:39 AM »
About an inch or so of play on the pedal.  No leaks around rear  main.  The arm seems to have as much motion as it should.  If the cable was too tight would it make the clutch slip?
1983 Toyota PU
« Reply #3 on: January 11, 2004, 09:01:39 AM »
Did ya put the disk in backwards?
« Reply #4 on: January 11, 2004, 10:44:06 AM »
Cable too tight or a frayed cable hanging up
could cause slippage, and the snout on the
clutch faces toward the trans not the flywheel.
Offline idaholwb
  • 772
« Reply #5 on: January 29, 2004, 04:44:06 PM »
 Check the clutch cable arm on the clutch pedal assembly, they break sometimes.
97 Sport
265/70-16s
2" lift
2.0 swap
Offline Somer
  • 143
  • Hey, is it suppose to do that!!
    • D2
« Reply #6 on: January 29, 2004, 08:54:27 PM »
I remember hearing about a clutch problem from someone on this board before, wasn't it caused by a crack somewhere or a faulty bolt? can't remember.. ???
