just not my day
  • 2122 Views
Offline zookiemike
  • 474
  • $,reppin Michigan,$
just not my day
« on: January 28, 2004, 05:09:07 AM »
Alright peep this i hit a deer at three o klock in the moring see (venisen) and just now my down pipe on my exhaust pipe BROKE ;D
                         "It's allways somthing"
Re: just not my day
« Reply #1 on: January 28, 2004, 05:26:58 AM »
That was your Zuk adjusting it's weight to compensate for the Deer Guts in the Grill ;) JK.
Dude that sucks. I hate having days like that.
Offline jagular7
  • 1026
  • Jagular7
Re: just not my day
« Reply #2 on: January 28, 2004, 05:57:29 AM »
Could be a good thing now, you'll have to change out the whole exhaust for a 2" system. Cool. However, this also depends on how cold it is outside for you to lay underneath the truck....
Lenexa, KS
Offline Speedracer7c
  • 2210
Re: just not my day
« Reply #3 on: January 28, 2004, 06:04:16 AM »
My downpipe is rotted on the flange too....one bolt doesn't seal the cat very well....hehehe
Offline zookiemike
  • 474
Re: just not my day
« Reply #4 on: January 28, 2004, 07:20:22 AM »
I got 2 inch exhaust under it already. It's just time for a header. any sugestons. 94 track 8 valve. MY tracker likes deer my sammys like'd trannys and t cases :P
« Last Edit: January 28, 2004, 07:22:36 AM by zookiemike »
Offline Z3bra
  • 273
Re: just not my day
« Reply #5 on: January 28, 2004, 07:34:18 AM »
Well, you're pretty much limited to one of 4 options with the header.  Calmini, Hawk, Thorley, or build your own.
By the look of it though the Hawk one looks like it might be a slightly better design with the longer primaries (better low end torque although tri-Y headers are somewhat odd compared to say a 4-1 header in that respect).
I have the Calmini one though and can't say anything bad about it so far.  I would probably avoid the Thorley unless you're in California since it's CARB certified and the other ones aren't.  The reason that I didn't get the Thorley is that the location of the O2 sensor on the Thorley one only feeds off two cylinders instead of all four so your 02 readings are going to possibly be a little bit off vs. the Calmini style where the 02 is reading off all four cylinders.
Might not be a big difference really but it just makes more sense to me to put it where it is on the Calmini headers.  I belive the older Calmini headers which are pretty much a copy of the Thorley otherwise also had the O2 sensor upstream of where all four pipes have converged into the collector.
